"A result set was generated for update." error for every alarm logged in the journal
I have an alarm journal on ignition 8.1.1 logging on a sql server 2016 database.
In the database default connection options “no count” is unchecked as is every other option.
Very often alarms don’t get logged and end up throwing this exception stack in the log:
com.microsoft.sqlserver.jdbc.SQLServerException: A result set was generated for update.
at com.microsoft.sqlserver.jdbc.SQLServerException.makeFromDriverError(SQLServerException.java:228)
at com.microsoft.sqlserver.jdbc.SQLServerPreparedStatement.doExecutePreparedStatement(SQLServerPreparedStatement.java:606)
at com.microsoft.sqlserver.jdbc.SQLServerPreparedStatement$PrepStmtExecCmd.doExecute(SQLServerPreparedStatement.java:522)
at com.microsoft.sqlserver.jdbc.TDSCommand.execute(IOBuffer.java:7194)
at com.microsoft.sqlserver.jdbc.SQLServerConnection.executeCommand(SQLServerConnection.java:2930)
at com.microsoft.sqlserver.jdbc.SQLServerStatement.executeCommand(SQLServerStatement.java:248)
at com.microsoft.sqlserver.jdbc.SQLServerStatement.executeStatement(SQLServerStatement.java:223)
at com.microsoft.sqlserver.jdbc.SQLServerPreparedStatement.executeUpdate(SQLServerPreparedStatement.java:471)
at org.apache.commons.dbcp2.DelegatingPreparedStatement.executeUpdate(DelegatingPreparedStatement.java:136)
at com.inductiveautomation.ignition.gateway.datasource.SRConnectionWrapper$SRPreparedStatement.executeUpdate(SRConnectionWrapper.java:1016)
at com.inductiveautomation.ignition.gateway.datasource.SRConnectionWrapper.runPrepInsertGetKey(SRConnectionWrapper.java:262)
at com.inductiveautomation.ignition.gateway.alarming.journal.DatabaseAlarmJournal$AlarmJournalSFData.storeToConnection(DatabaseAlarmJournal.java:342)
at com.inductiveautomation.ignition.gateway.alarming.journal.DatabaseAlarmJournal.storeRawEvent(DatabaseAlarmJournal.java:223)
at com.inductiveautomation.ignition.gateway.alarming.journal.AbstractAlarmJournal.storeEvent(AbstractAlarmJournal.java:55)
at com.inductiveautomation.ignition.gateway.alarming.journal.AlarmJournalManagerImpl.storeEvent(AlarmJournalManagerImpl.java:281)
at com.inductiveautomation.ignition.gateway.alarming.AlarmManagerImpl.transitionAlarm(AlarmManagerImpl.java:499)
at com.inductiveautomation.ignition.gateway.alarming.evaluation.Alarm.processTransition(Alarm.java:905)
at com.inductiveautomation.ignition.gateway.alarming.evaluation.Alarm.systemAck(Alarm.java:953)
at com.inductiveautomation.ignition.gateway.alarming.evaluation.Alarm.pushCurrentEvent(Alarm.java:936)
at com.inductiveautomation.ignition.gateway.alarming.evaluation.Alarm.finishTransitionEvent(Alarm.java:850)
at com.inductiveautomation.ignition.gateway.alarming.evaluation.Alarm.initTransitionEvent(Alarm.java:773)
at com.inductiveautomation.ignition.gateway.alarming.evaluation.Alarm.evaluate(Alarm.java:589)
at com.inductiveautomation.ignition.gateway.alarming.AlarmManagerImpl$AlarmEvaluatorImpl.evaluate(AlarmManagerImpl.java:675)
at com.inductiveautomation.ignition.gateway.tags.actors.factories.alarming.AlarmingActor.processValue(AlarmingActor.java:216)
at com.inductiveautomation.ignition.gateway.tags.runtime.nodes.ExecutableTag.valueChanged(ExecutableTag.java:395)
at com.inductiveautomation.ignition.gateway.tags.actors.factories.value.AbstractValueGeneratingActor.fireValueChange(AbstractValueGeneratingActor.java:71)
at com.inductiveautomation.ignition.gateway.tags.actors.factories.value.AbstractValueGeneratingActor.fireValueChange(AbstractValueGeneratingActor.java:45)
at com.inductiveautomation.ignition.gateway.tags.actors.factories.value.opc.OpcActorFactory$OpcActor.setValue(OpcActorFactory.java:783)
at com.inductiveautomation.ignition.gateway.opcua.client.connection.OpcUaSubscriptionSynchronizer$DataValueConsumer.accept(OpcUaSubscriptionSynchronizer.kt:592)
at com.inductiveautomation.ignition.gateway.opcua.client.connection.OpcUaSubscriptionSynchronizer$DataValueConsumer.accept(OpcUaSubscriptionSynchronizer.kt:563)
at org.eclipse.milo.opcua.sdk.client.subscriptions.OpcUaMonitoredItem.lambda$setValueConsumer$0(OpcUaMonitoredItem.java:148)
at org.eclipse.milo.opcua.sdk.client.subscriptions.OpcUaMonitoredItem.onValueArrived(OpcUaMonitoredItem.java:218)
at org.eclipse.milo.opcua.sdk.client.subscriptions.OpcUaSubscriptionManager.lambda$null$41(OpcUaSubscriptionManager.java:690)
at org.eclipse.milo.opcua.stack.core.util.ExecutionQueue$Task.run(ExecutionQueue.java:119)
Any clue about where the problem might be?
