A windows to manage SqlTags Select and Read / Write from Vison Client :
Required : The wonderfull
IA Labs Scripting Module
http://marketplace.inductiveautomation.com/moduledetail?2&moduleId=46
Import the windows
[attachment=1]DebugSqlTagsWin_2014-02-14_1614_partial.proj[/attachment]
Dezip add the bitmap in Ignition Image management :
[attachment=0]ico.zip[/attachment]
Select TagPath in the tree and press the button “LIST TAG”
In the result table,select a tag line, Right mouse click to :
[ul]Command Read_Write Tag[/ul]
[ul]Toogle if boolean[/ul]
[ul]Show Alarms config detail[/ul]
Becareful for cyclic Read if too many tag are selected with a too fast update rate (few seconds)
Export buuton to save list as html/xls
Feedbacks are welcome.
Hope this help !
