i have a DF1 network. I’m assuming i need to set that up as a device at the ignition gateway but i don’t see that as an option. Am i way off track here or are there more drivers i can download? You will have to bear with me guys. I’m new to this. ![]()
All of the driver modules for Ignition are Ethernet drivers. If you want to communicate with devices on a DF1 network you’ll need to go through a gateway or converter of some kind.
Alternatively, you can use Kepware or any other OPC server with the drivers that you need. Ignition talks to any OPC-DA or OPC-UA server.
