Hello! I am new in ignition,
I tried to use AB Logix driver to connect AB CompactLogix PLC (V21+), from OPC UA\Device connection, add new device via AB Logix driver and connected to PLC, but from OPC Client\OPC Quick Client, there is not PLC appear and also cannot see the PLC tags, please advise what is the problem?
my ignition V8.0, trial license
device setting all keep default setting, only Name and controller IP changed accordingly,
I noticed Ignition V8.0 Device setting has Connectivity Port : 44818 (default), don’t know what is meaning? whether OPC connection need to be set?
