Hi! I'm having some trouble when inserting a datetime into database. I'm running a runPrepStatement over an insert query and when i log the data i'm persisting it appears to be OK, but, when its persisted timezone seems to change. I've setted project timezone to different timezones and nothing changes, neither the timezone of the project nor the timezone of the persisted date. I've tried to force select bringing the date at time zone 'utc' and this crashes... I assume the best way is to store data in utc but no idea of how can i do this if project propperties does nothing and its hard to import third party libraries such as pytz so i can "play" with timezones on python code.
Regards, Jorge
EDIT: The problem was ignition doesn not work well with python datetimes because of milliseconds. I tried using system.date.now() instead of datetime.now() and now all works fine with sql server datetime column type.
