this is what the console shows:
eryStatus(AbstractAlarmUtilities.java:61)
at sun.reflect.GeneratedMethodAccessor29.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
com.inductiveautomation.ignition.client.gateway_interface.GatewayException: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Post Error, error code = 503
at org.python.core.Py.JavaError(Py.java:495)
at com.inductiveautomation.ignition.common.script.builtin.AbstractAlarmUtilities.queryStatus(AbstractAlarmUtilities.java:63)
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:186)
at com.inductiveautomation.ignition.common.script.ScriptManager$ReflectedInstanceFunction.__call__(ScriptManager.java:406)
at org.python.core.PyObject.__call__(PyObject.java:320)
at org.python.pycode._pyx0.f$0(<expression:runScript>:1)
at org.python.pycode._pyx0.call_function(<expression:runScript>)
at org.python.core.PyTableCode.call(PyTableCode.java:165)
at org.python.core.Py.runCode(Py.java:1275)
at com.inductiveautomation.ignition.common.script.ScriptManager.runCode(ScriptManager.java:551)
... 26 more
Caused by: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Post Error, error code = 503
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.newGatewayException(GatewayInterface.java:326)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.newGatewayException(GatewayInterface.java:322)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.getResponse(GatewayInterface.java:410)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:262)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:257)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.invoke(GatewayInterface.java:803)
at com.inductiveautomation.factorypmi.application.script.builtin.ClientAlarmUtilities.queryStatusImpl(ClientAlarmUtilities.java:40)
at com.inductiveautomation.ignition.common.script.builtin.AbstractAlarmUtilities.queryStatus(AbstractAlarmUtilities.java:61)
… 38 more
WARN [ExpressionPropertyAdapter-AWT-EventQueue-2] Error executing expression binding on
Alarm Count Label.Alarm Count Label.count
java.lang.Exception: Error executing expression binding on
at com.inductiveautomation.factorypmi.application.binding.ExpressionPropertyAdapter.runExpression(ExpressionPropertyAdapter.java:82)
at com.inductiveautomation.factorypmi.application.binding.ExpressionPropertyAdapter.childInteractionUpdated(ExpressionPropertyAdapter.java:50)
at com.inductiveautomation.ignition.common.expressions.functions.AbstractPollingFunction.actionPerformed(AbstractPollingFunction.java:80)
at javax.swing.Timer.fireActionPerformed(Unknown Source)
at javax.swing.Timer$DoPostEvent.run(Unknown Source)
at java.awt.event.InvocationEvent.dispatch(Unknown Source)
at java.awt.EventQueue.access$200(Unknown Source)
at java.awt.EventQueue$3.run(Unknown Source)
at java.security.ProtectionDomain$1.doIntersectionPrivilege(Unknown Source)
Caused by: com.inductiveautomation.ignition.common.expressions.ExpressionException: Error executing script for runScript() expression:len(system.alarm.queryStatus(state=[“ActiveUnacked”,“ActiveAcked”]))
at com.inductiveautomation.ignition.common.expressions.functions.ScriptFunction.execute(ScriptFunction.java:62)
at com.inductiveautomation.ignition.common.expressions.FunctionExpression.execute(FunctionExpression.java:69)
at com.inductiveautomation.ignition.common.expressions.DefaultFunctionFactory$CastFunction.execute(DefaultFunctionFactory.java:1468)
at com.inductiveautomation.ignition.common.expressions.DefaultFunctionFactory$IfFunction.execute(DefaultFunctionFactory.java:1393)
at com.inductiveautomation.factorypmi.application.binding.ExpressionPropertyAdapter.runExpression(ExpressionPropertyAdapter.java:73)
… 18 more
Caused by: Traceback (most recent call last):
File “expression:runScript”, line 1, in
at com.inductiveautomation.ignition.common.script.ScriptManager.runCode(ScriptManager.java:554)
at com.inductiveautomation.ignition.common.script.ScriptManager.runCode(ScriptManager.java:544)
at com.inductiveautomation.ignition.common.expressions.functions.ScriptFunction.execute(ScriptFunction.java:59)
... 24 more
... 26 more
… 38 more
… 18 more
