AbstractVisionPanel SerializationException
Hello All,
I’m creating a component that extends from AbstractVisionPanel. It has a main class registered with the related bean info, and it is made up from roughly 12 other classes. Everything works as it should mostly in the designer. However, when I save the windows, I get the following error.
com.inductiveautomation.ignition.common.xmlserialization.SerializationException: Error during serialization for property 'contentPane' on object '[FPMIWindow]Main Window (1)'
	at com.inductiveautomation.ignition.common.xmlserialization.serialization.DefaultObjectSerializationDelegate.serializeProperties(DefaultObjectSerializationDelegate.java:300)
	at com.inductiveautomation.factorypmi.designer.xmlserialization.WindowDelegate.serialize(WindowDelegate.java:29)
	at com.inductiveautomation.ignition.common.xmlserialization.serialization.XMLSerializationContext.serialize(XMLSerializationContext.java:45)
	at com.inductiveautomation.ignition.common.xmlserialization.serialization.XMLSerializer.serialize(XMLSerializer.java:430)
	at com.inductiveautomation.ignition.common.xmlserialization.serialization.XMLSerializer.serializeBinary(XMLSerializer.java:412)
	at com.inductiveautomation.factorypmi.designer.workspace.WindowWorkspace.saveContainer(WindowWorkspace.java:1525)
	at com.inductiveautomation.factorypmi.designer.workspace.WindowWorkspace.commitDesignable(WindowWorkspace.java:1211)
	at com.inductiveautomation.factorypmi.designer.workspace.WindowWorkspace.commitAll(WindowWorkspace.java:607)
	at com.inductiveautomation.factorypmi.designer.model.VisionDesignerImpl.notifyProjectSaveStart(VisionDesignerImpl.java:955)
	at com.inductiveautomation.ignition.designer.IgnitionDesigner.handleSave(IgnitionDesigner.java:1286)
	at com.inductiveautomation.ignition.designer.IgnitionDesigner.access$2800(IgnitionDesigner.java:204)
	at com.inductiveautomation.ignition.designer.IgnitionDesigner$Handler.handleSaveAction(IgnitionDesigner.java:1873)
	at com.inductiveautomation.ignition.designer.IgnitionDesigner$Handler.access$1300(IgnitionDesigner.java:1433)
	at com.inductiveautomation.ignition.designer.IgnitionDesigner$Handler$6.actionPerformed(IgnitionDesigner.java:1551)
	at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
	at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
	at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
	at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
	at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Source)
	at com.jidesoft.plaf.basic.BasicJideButtonListener.mouseReleased(Unknown Source)
	at java.awt.AWTEventMulticaster.mouseReleased(Unknown Source)
	at java.awt.Component.processMouseEvent(Unknown Source)
	at javax.swing.JComponent.processMouseEvent(Unknown Source)
	at java.awt.Component.processEvent(Unknown Source)
	at java.awt.Container.processEvent(Unknown Source)
	at java.awt.Component.dispatchEventImpl(Unknown Source)
	at java.awt.Container.dispatchEventImpl(Unknown Source)
	at java.awt.Component.dispatchEvent(Unknown Source)
	at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
	at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
	at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
	at java.awt.Window.dispatchEventImpl(Unknown Source)
	at java.awt.EventQueue.access$200(Unknown Source)
	at java.awt.EventQueue$3.run(Unknown Source)
	at java.security.ProtectionDomain$1.doIntersectionPrivilege(Unknown Source)
	at java.awt.EventQueue$4.run(Unknown Source)
Caused by: com.inductiveautomation.ignition.common.xmlserialization.SerializationException: Error during serialization for property 'layout' on object '[MapPanel]com.koerr.client.components.MapPanel[MapPanel,29,23,593x419,layout=java.awt.FlowLayout,alignmentX=0.0,alignmentY=0.0,border=,flags=16777481,maximumSize=,minimumSize=,preferredSize=]'
	at com.inductiveautomation.factorypmi.designer.xmlserialization.DefaultComponentDelegate.serializeProperties(DefaultComponentDelegate.java:109)
	at com.inductiveautomation.ignition.common.xmlserialization.serialization.DefaultObjectSerializationDelegate.serialize(DefaultObjectSerializationDelegate.java:323)
	at com.inductiveautomation.ignition.common.xmlserialization.serialization.DefaultObjectSerializationDelegate.writeCall(DefaultObjectSerializationDelegate.java:229)
	at com.inductiveautomation.factorypmi.designer.xmlserialization.BasicContainerDelegate.serializeProperties(BasicContainerDelegate.java:121)
	at com.inductiveautomation.factorypmi.designer.xmlserialization.BasicContainerDelegate.serialize(BasicContainerDelegate.java:42)
	at com.inductiveautomation.ignition.common.xmlserialization.serialization.DefaultObjectSerializationDelegate.writeCall(DefaultObjectSerializationDelegate.java:218)
	at com.inductiveautomation.ignition.common.xmlserialization.serialization.DefaultObjectSerializationDelegate.doProperty(DefaultObjectSerializationDelegate.java:271)
	at com.inductiveautomation.ignition.common.xmlserialization.serialization.DefaultObjectSerializationDelegate.serializeProperties(DefaultObjectSerializationDelegate.java:298)
	... 51 more
Caused by: com.inductiveautomation.ignition.common.xmlserialization.SerializationException: Unable to create clean copy of class com.koerr.client.components.MapPanel$MapLayout
	at com.inductiveautomation.ignition.common.xmlserialization.serialization.XMLSerializer.getCleanCopy(XMLSerializer.java:494)
	at com.inductiveautomation.ignition.common.xmlserialization.serialization.XMLSerializationContext.getCleanCopy(XMLSerializationContext.java:67)
	at com.inductiveautomation.ignition.common.xmlserialization.serialization.DefaultObjectSerializationDelegate.serializeProperties(DefaultObjectSerializationDelegate.java:289)
	... 62 more
Ignition v7.5.5-beta5 (b1234)
Java: Oracle Corporation 1.7.0_11
I’m not sure where to start. Any pointers on where to start?
Well, it looks like your MapLayout class isn’t quite compatible with the XML serialization. Maybe it’s missing a constructor or a setter that it needs in order to make a clean copy?
Thanks Kevin. I didn’t have my beaninfos search set properly. All good now.
Hey Kyle I’m having the exact same issue here, what exactly did you do to fix it?
