Is there a way to access the script behind a component on a windows and retrieve it into say a string.
I am upgrading an older project and have multiple menu screens driven by individual buttons which I am improving to a dynamic menu screen using templates, template repeaters to make it more manageable.
Rather than re-type all the button information into the dataset that drives the new screen I have a script which will iterate through all the existing buttons on a page and retrieve the button text and image references to a dataset, if I could also get the script into a string I could parse it to get the window name called by the original button.
I can see in a pages XML export the code is in there using setJytonCode method, but as I have already the script to scan through the components would like to see if I can get access to the code through Ignition.
thanks
