Access root container on different page
Hello,
I am using Vision.
As the title says, my question is if there is a way to access the components from a root container, on a different page than it is addressed from.
I have one window with buttons, that I would like to make a change on a different page, but without the use of internal memory tags. Therefore, a direct way to address the root container on the page is required.
Thanks in advance.
You can use system.gui.getOpenedWindows() to get a reference to the window, and then get access to any component from there. I’m away from my computer at the moment so can’t really write out a reference script.
You can look in the manual for an example of how to use that function.
Or just use system.gui.getWindow() if you know the window name.
And from here
window = system.gui.getWindow("Some window path")
rc = window.getRootContainer()
# at this point you can chain together getComponent's
# to get what you need if its nested inside other components/containers
someComponent = rc.getComponent("someComponent")
Thanks for all your reply’s :slight_smile:
Made it work
