I saved some images located in webserver/webapps/myfolder/ and I'm trying to access via Image Display Component Source but I don't exactly the syntax of the directory or if is possible to access to there.
Our Ignition stuff is hosted remotely, so it would start http://ipserver:port/...
Is this in perspective or vision?
In the designer you need to go to image management and add your photos there
then in the source of your image add /system/images/ to the beginning of the path to your image.
you can right click and get a context menu to copy the path to it
I realize I missed the part about remotely. Still waking up today
As long as Ignition has access to the server where the files are stored a web address should do it.
I'm saving the images in webserver/webapps/myfolder/ via script and that is working but I need to access them just by clicking a row in a table. http://ipserver:port/ let me access to webserver/webapps/main but I need to access to a folder located in webapps not in main.
That is kind of out of Ignitions hands. Whatever is hosting the files at webserver/webapps/myfolder/ will have to be able to supply access to that folder from a web url such as http://127.0.0.1:1234/webserver/webapps/myfolder
As an example look at the bottom of this doc at the inductive logo supplied via a url
Perspective - Image | Ignition User Manual (inductiveautomation.com)
