Hello together
I am having difficulty accessing individual BACnet properties in the Ignition Designer.
In the concrete case it is about accessing the property of a binary input. The binary input is found in the OPC Tag Browser, but not all properties are displayed.
I have now tried to access the desired property with a manually created OPC Tag and a customized Tag Path which unfortunately did not work.
My manually created OPC tag with customized path for “Elapsed_Active_Time”.
Has anyone had similar difficulties or have an idea how I could go further?
Well, I was able to access another property, Present Value, via a manually created OPC tag. What has confused me a bit now.
Thank you for your support!
