Access to Vision Symbol Factory SVG Files
New to ignition here. Is there a way that I can access the symbol factory SVG files outside of the designer? Basically the customer wants to have a go at laying out their own screen offline in an image editor using the same graphics. Once they are happy, i will reproduce the screen within the designer. This will save time going backwards and forwards to get what they want.
No, it's part of the licensed package. There are other third-party image libraries available with similar images.
Thanks for your response!
This is what i thought. I'll try find a similar third-party library that achieves the same thing. Can you suggest any off the top of your head?
Thanks.
Why not have them download and install ignition and then they can play around all they want.
Because, unless licensed, you can only access the first image in each set.
https://www.opto22.com/support/resources-tools/demos/svg-image-library
Thanks, Ill check those out.
That was a consideration
