Accessing Alarm Associated Data in scripting
Is it possible to access associated alarm data from alarm objects return by the system.alarm.queryStatus() function?
Finally found a solution and share that here in case it is useful to anyone else.
Basically the activeData object of each alarm in the list returned form system.alarm.queryStatus() has a bunch of properties within that include any associated(Custom) properties, by iterating though all the activeData properties and building a Python Dict, I could then test the Dict keys to see if my associated data was present, I guess there is better way but it works.
alarms = system.alarm.queryStatus( priority	= ['Low', 'Medium', 'High', 'Critical'],
                                   state	= ["ActiveUnacked", "ActiveAcked"]
for alarm in alarms:
	props={}
	for item in alarm.activeData:
		props[str(item.getProperty())]=item.getValue()
	if 'associatedDataName ' in props.keys():
		Process the property here
How do you process the property. I have associated data named group and can print the prop that shows the he prop data including yhe group but i can figure out how to test if that group equals something do something else
if 'associatedDataName' in props.keys():
	#processing associated data example:
	associatedDataValue = props['associatedDataName']
	print associatedDataValue #do something with this value
This works nicely. My Associated Data name is Alarm Description.
eventID = [("EventId","=","255600b2-fa1c-4182-9660-a405ee11e572")]
results = system.alarm.queryStatus(all_properties=eventID)
result = results[0]
print("result property Alarm Description = " + str(result.get("Alarm Description")))
