The ControlLogix UDT, (recipe) contains a boolean array named InhibitFlags[32]. The ControlLoigix-UDT imports the array as tags in a folder in the Ignition-UDT as /Recipe/InhibitFlags/InhibitFlags_XX, with XX being the array index.
There are 20 check boxes on a screen, each addressed to /Recipe/InhibitFlags/InhibitFlags_1 through /Recipe/InhibitFlags/InhibitFlags_20, but no matter which one used in the PLC only Recipe.OffsetInhibitFlags[0] is set or cleared, and all check boxes are reading the same. The tags all appear to be addressed right in the PLC and I’ve even re-browsed to a few of them just to make sure.
Do I need to be doing something different to access an array in a UDT?
Using version 7.7.1.
