How straightforward is it to access the data that is stored in a FactoryTalk Historian SE server from Ignition? I've seen various other posts that say OPC HDA is required and some posts that that say using a PI JDBC driver is sufficient to connect to it since FactoryTalk Historian SE uses PI Historian. Is there another way to access the historian data?
Here is an article that I found related to using the JDBC driver to access an OSI PI installation for reference, however I'm not sure if this is applicable to a FactoryTalk Historian SE instance:
JDBC Driver - OSI PI
