Accessing individual bits in controllogix
This thread is pretty old…
We are trying to use the notation “[Device,bit=1]Variable” in control logix. At first it seems to work but all thoses tags:
“[Device,bit=0]Variable”
“[Device,bit=2]Variable”
They all seems to adress the same bit (bit 0).
Any idea?
I have never seen this syntax. Where did you find it? The OPC item address for a logix bit of a DINT is dot-bit number as a suffix. Like [Device]Variable.0 or [Device]Variable.31.
Never mind. Top of the old topic. Never had to do that. /-:
I’m confused. Where did we land on this? Can we access individual bits of a DINT in controllogix for read and write?
I haven’t been able to get it to work.
Use the dot-number suffix syntax. Works for me.
I have a button script with:
system.tag.writeSynchronous(“CLX064/IGN_Bit_Test.2”, 1, 5000)
I get this error:
Tag property ‘2’ is not a valid property
What should the syntax be in this example?
Never mind. I figured it out. I had to set it up in the Tag Browser with the .2 as a boolean.
Thanks for the help.
You could have also used system.opc.writeValue (and the appropriate OPC Item Path), which will work even if you don’t have a tag set up for it in the Tag Browser.
Thanks!
I didn’t realize I could do that. That will help a lot.
