Accessing Network Video Files in Ignition Web Dev Module
I'm new to the Ignition environment and currently working on a page using the Web Dev module. I'm trying to access some video files that are located on a network folder, but I haven't been able to get it to work.
Is it possible to access video files on a network share through the Web Dev module?
Here's a simplified version of the code I'm using:
def doGet(request, session):
  # Try these alternative path formats one by one:
  test_file = "Z:/Information Technology/Test_Videos/010-010/test.mp4"  # Forward slashes
  # test_file = r"Z:\Information Technology\Test_Videos\010-010\test.mp4"  # Raw string
  # test_file = "\\\\ServerName\\ShareName\\Information Technology\\Test_Videos\\010-010\\test.mp4"  # UNC path
  try:
      import os
      print("Attempting to access:", test_file)  # This appears in the gateway logs
      print("Path exists:", os.path.exists(test_file))  # Debug output
      if not os.path.exists(test_file):
          return {
              'json': {'error': "File not found at: " + test_file},
              'debug': {
                  'current_dir': os.getcwd(),
                  'list_dir': os.listdir(os.path.dirname(test_file))
              'status': 404
      return {'file': test_file, 'contentType': 'video/mp4'}
  except Exception as e:
      return {'json': {'error': "Access error: " + str(e)}, 'status': 500}
I've tried using different path formats, including drive letters and UNC paths, but none of them seem to work. I'm not sure if I'm missing something in terms of configuration or permissions.
Any guidance on how to properly access network files in this context would be greatly appreciated. Thank you in advance for your help!
The gateway runs as a service, and by default does not have network share access. You should reconfigure the service to run as a domain user that has suitable share access, and use UNC paths (no drive letters).
