The network on which we are connected to an AB Compact logix has been upgraded to a VLan network and since the upgrade we have lost connection to PLC and recieving this error.
We are running Ignition V7.5.6
java.lang.Exception: Error connecting to “10.32.15.91”.
com.inductiveautomation.xopc.driver.api.AbstractNioDriver.connect(AbstractNioDriver.java:136)
com.inductiveautomation.xopc.driver.api.AbstractDriver$5.run(AbstractDriver.java:534)
com.inductiveautomation.ignition.common.execution.impl.BasicExecutionEngine$ThrowableCatchingRunnable.run(BasicExecutionEngine.java:526)
java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
java.util.concurrent.FutureTask$Sync.innerRun(Unknown Source)
java.util.concurrent.FutureTask.run(Unknown Source)
java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(Unknown Source)
java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(Unknown Source)
java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unknown Source)
java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
java.lang.Thread.run(Unknown Source)
java.net.ConnectException: Connection timed out: connect
java.net.PlainSocketImpl.socketConnect(Native Method)
java.net.PlainSocketImpl.doConnect(Unknown Source)
java.net.PlainSocketImpl.connectToAddress(Unknown Source)
java.net.PlainSocketImpl.connect(Unknown Source)
java.net.SocksSocketImpl.connect(Unknown Source)
java.net.Socket.connect(Unknown Source)
com.inductiveautomation.xopc.driver.api.AbstractNioDriver.connect(AbstractNioDriver.java:110)
