I have a simple code below, I have set the printer name and set the print dialog to False. My question is how i can access or code the number of copies with a given value by the user
report = event.source.parent.getComponent('Report Viewer')
report.print("EPSON TM-T82II Receipt5",0)
You can’t, directly. Something like this may work:
from org.apache.commons.lang3.reflect import FieldUtils
def setCopies(component, copies):
rmViewer = FieldUtils.readField(component, "reportView", True)
rmViewer.copies = copies
Which you would use something like this:
setCopies(event.source.parent.getComponent("Report Viewer"), 3)
It seems the code doesn’t work.
Well, if you can provide any detail about what ‘doesn’t work’ means - is an error thrown? Where are you applying the code? I might be able to help.
It does not throw any errors,
Maybe constructing/applying code
I want to elaborate what the program should do
i have a report viewer(barcode) and a default printer, the printer should printer the report viewer for a example 4 times.depends othe the input quantity
