I try following the expression in the Alarm Display Path to get the tag Eng Unit metadata but the tag() function returns nothing:
{PathToParentFolder} + " Critical Range " + {value} + " " + tag({PathToTag} + ".EngUnit")
So how can we read the tag ".EngUnit" here?
Messed around with all kinds of properties and ended up with
tag(concat({itemPath},'.EngUnit'))
Using PathToParentFolder or FullItemPath ends up having 'default' doubled up in the tag path.
The tag diagnostics showed the path as
[default]default/Global/alarmTestTag
Why using simple + operand doesn't work here?
