Using 7.7.0 - If a tag’s alarm is set to require acknowledgement notes, it is possible to acknowledge the alarm from one of the notification profiles without an acknowledgement note. That in itself is understandable since there are no provisions in the alarm notification profiles for adding an acknowledgement note.
The problem is that if an alarm is required to have acknowledgement notes, the alarm is acknowledged through one of the notification profiles and the alarm clears it is removed from the Alarm Status Table even though the alarm has no acknowledgement notes.
An alarm that requires acknowledgement notes should not be removed from the Alarm Status Table until it has and acknowledgement note.
