Hello,
I wanted to activate a boolean tag for a specific time, and automatically deactivate it when that time passes. any ideas to do it?
thank you
Hello,
thank you
Use an expression tag to setup your timing, then on a tag change event run a script to configure the tag’s enabled attribute of the tag you want to control for v8, for v7.9 you will edit tag
EDIT Not sure if I miss read your post, but the above is to enable and disable the tag, if you want a flasher type function on a Boolean try this in an expression.
toMillis(now(5000)) % 10000 < 5000
This will flash on and off for 5 sec intervals
thanks for your reply.
I will test with your solution.
