Ignition 8.1.10 on Windows Server
We are having trouble retrieving users and roles from an Active Directory User source. The error messages is posted below. Any assistance pointing in the correct direction is greatly appreciated!
INFO | jvm 1 | 2021/10/25 13:19:39 | W [U.ActiveDirectory ] [17:19:39]: [profileName=client_name_AD] Unable to read group attribute "cn" from group "CN=PPDL Innovation team CampX,OU=DistributionLists,OU=Exchange,OU=CS,DC=vcn,DC=ds,DC=client_name,DC=net", using distinguished name instead.
INFO | jvm 1 | 2021/10/25 13:19:39 | javax.naming.CommunicationException: Connection reset
INFO | jvm 1 | 2021/10/25 13:19:39 | at java.naming/com.sun.jndi.ldap.LdapCtx.doSearch(Unknown Source)
INFO | jvm 1 | 2021/10/25 13:19:39 | at java.naming/com.sun.jndi.ldap.LdapCtx.doSearchOnce(Unknown Source)
INFO | jvm 1 | 2021/10/25 13:19:39 | at java.naming/com.sun.jndi.ldap.LdapCtx.c_getAttributes(Unknown Source)
INFO | jvm 1 | 2021/10/25 13:19:39 | at java.naming/com.sun.jndi.toolkit.ctx.ComponentDirContext.p_getAttributes(Unknown Source)
INFO | jvm 1 | 2021/10/25 13:19:39 | at java.naming/com.sun.jndi.toolkit.ctx.PartialCompositeDirContext.getAttributes(Unknown Source)
INFO | jvm 1 | 2021/10/25 13:19:39 | at java.naming/javax.naming.directory.InitialDirContext.getAttributes(Unknown Source)
INFO | jvm 1 | 2021/10/25 13:19:39 | at com.inductiveautomation.ignition.gateway.authentication.impl.ActiveDirectoryUserSource$UserSearchHandler$RoleLoader.load(ActiveDirectoryUserSource.java:314)
INFO | jvm 1 | 2021/10/25 13:19:39 | at com.inductiveautomation.ignition.gateway.authentication.impl.ActiveDirectoryUserSource$UserSearchHandler$RoleLoader.load(ActiveDirectoryUserSource.java:299)
INFO | jvm 1 | 2021/10/25 13:19:39 | at com.google.common.cache.LocalCache$LoadingValueReference.loadFuture(LocalCache.java:3708)
INFO | jvm 1 | 2021/10/25 13:19:39 | at com.google.common.cache.LocalCache$Segment.loadSync(LocalCache.java:2416)
INFO | jvm 1 | 2021/10/25 13:19:39 | at com.google.common.cache.LocalCache$Segment.lockedGetOrLoad(LocalCache.java:2299)
INFO | jvm 1 | 2021/10/25 13:19:39 | at com.google.common.cache.LocalCache$Segment.get(LocalCache.java:2212)
INFO | jvm 1 | 2021/10/25 13:19:39 | at com.google.common.cache.LocalCache.get(LocalCache.java:4147)
INFO | jvm 1 | 2021/10/25 13:19:39 | at com.google.common.cache.LocalCache.getOrLoad(LocalCache.java:4151)
INFO | jvm 1 | 2021/10/25 13:19:39 | at com.google.common.cache.LocalCache$LocalLoadingCache.get(LocalCache.java:5140)
INFO | jvm 1 | 2021/10/25 13:19:39 | at com.inductiveautomation.ignition.gateway.authentication.impl.ActiveDirectoryUserSource$UserSearchHandler.endBatch(ActiveDirectoryUserSource.java:347)
INFO | jvm 1 | 2021/10/25 13:19:39 | at com.inductiveautomation.ignition.gateway.authentication.impl.LDAPHelper.search(LDAPHelper.java:396)
INFO | jvm 1 | 2021/10/25 13:19:39 | at com.inductiveautomation.ignition.gateway.authentication.impl.LDAPHelper.search(LDAPHelper.java:342)
INFO | jvm 1 | 2021/10/25 13:19:39 | at com.inductiveautomation.ignition.gateway.authentication.impl.ActiveDirectoryUserSource.getUsers(ActiveDirectoryUserSource.java:175)
INFO | jvm 1 | 2021/10/25 13:19:39 | at com.inductiveautomation.ignition.gateway.authentication.UserSourceWrapper.doGetUsers(UserSourceWrapper.java:411)
INFO | jvm 1 | 2021/10/25 13:19:39 | at com.inductiveautomation.ignition.gateway.authentication.UserSourceWrapper$UserCacheImpl.doUpdate(UserSourceWrapper.java:268)
INFO | jvm 1 | 2021/10/25 13:19:39 | at com.inductiveautomation.ignition.gateway.authentication.UserSourceWrapper$UserCacheImpl.doUpdate(UserSourceWrapper.java:264)
INFO | jvm 1 | 2021/10/25 13:19:39 | at com.inductiveautomation.ignition.gateway.authentication.AbstractCache$UpdateTask.run(AbstractCache.java:118)
INFO | jvm 1 | 2021/10/25 13:19:39 | at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
INFO | jvm 1 | 2021/10/25 13:19:39 | at java.base/java.util.concurrent.FutureTask.run(Unknown Source)
INFO | jvm 1 | 2021/10/25 13:19:39 | at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
INFO | jvm 1 | 2021/10/25 13:19:39 | at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
INFO | jvm 1 | 2021/10/25 13:19:39 | at java.base/java.lang.Thread.run(Unknown Source)
INFO | jvm 1 | 2021/10/25 13:19:39 | Caused by: javax.net.ssl.SSLException: Connection reset
INFO | jvm 1 | 2021/10/25 13:19:39 | at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source)
INFO | jvm 1 | 2021/10/25 13:19:39 | at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source)
INFO | jvm 1 | 2021/10/25 13:19:39 | at java.base/sun.security.ssl.SSLSocketImpl.handleException(Unknown Source)
INFO | jvm 1 | 2021/10/25 13:19:39 | at java.base/sun.security.ssl.SSLSocketImpl$AppInputStream.read(Unknown Source)
INFO | jvm 1 | 2021/10/25 13:19:39 | at java.base/java.io.BufferedInputStream.fill(Unknown Source)
INFO | jvm 1 | 2021/10/25 13:19:39 | at java.base/java.io.BufferedInputStream.read1(Unknown Source)
INFO | jvm 1 | 2021/10/25 13:19:39 | at java.base/java.io.BufferedInputStream.read(Unknown Source)
INFO | jvm 1 | 2021/10/25 13:19:39 | at java.naming/com.sun.jndi.ldap.Connection.run(Unknown Source)
INFO | jvm 1 | 2021/10/25 13:19:39 | ... 1 common frames omitted
INFO | jvm 1 | 2021/10/25 13:19:39 | Suppressed: java.net.SocketException: Connection reset by peer: socket write error
INFO | jvm 1 | 2021/10/25 13:19:39 | at java.base/java.net.SocketOutputStream.socketWrite0(Native Method)
INFO | jvm 1 | 2021/10/25 13:19:39 | at java.base/java.net.SocketOutputStream.socketWrite(Unknown Source)
INFO | jvm 1 | 2021/10/25 13:19:39 | at java.base/java.net.SocketOutputStream.write(Unknown Source)
INFO | jvm 1 | 2021/10/25 13:19:39 | at java.base/sun.security.ssl.SSLSocketOutputRecord.encodeAlert(Unknown Source)
INFO | jvm 1 | 2021/10/25 13:19:39 | ... 10 common frames omitted
INFO | jvm 1 | 2021/10/25 13:19:39 | Caused by: java.net.SocketException: Connection reset
INFO | jvm 1 | 2021/10/25 13:19:39 | at java.base/java.net.SocketInputStream.read(Unknown Source)
INFO | jvm 1 | 2021/10/25 13:19:39 | at java.base/sun.security.ssl.SSLSocketInputRecord.read(Unknown Source)
INFO | jvm 1 | 2021/10/25 13:19:39 | at java.base/sun.security.ssl.SSLSocketInputRecord.readHeader(Unknown Source)
INFO | jvm 1 | 2021/10/25 13:19:39 | at java.base/sun.security.ssl.SSLSocketInputRecord.bytesInCompletePacket(Unknown Source)
INFO | jvm 1 | 2021/10/25 13:19:39 | at java.base/sun.security.ssl.SSLSocketImpl.readApplicationRecord(Unknown Source)
INFO | jvm 1 | 2021/10/25 13:19:39 | ... 6 common frames omitted
