I am in the process of migrating from an Active Directory/Internal Hybrid type authentication scheme to a pure AD authentication scheme. We will soon be splitting to a server-per-facilityr setup and this will make managing user roles easier.
If I dump the System->User->RoleString SQLTag to a list, and all of the active directory groups that I am a member of show up. However, these do not show up on the tag in the designer, which appears empty. Also, in the “Manage Users” section for this profile on the gateway, the only user/role that shows up is admin & Administrator.
I believe this is why when I select a component, and click on the security pane, the only role that shows up is Administrator. I would like to be able to use checkboxes to select roles if possible. I’m sure since the roles show up to the list I’m dumping to, I could use a script on the component to check if a user is part of a specific role, but that is not an ideal solution. Any suggestions?
Edit: This is on version 7.6.2-rc4 (b2365).
