@Active duration@ in hours Rather than days format?
Hi
When I am using the Active Duration from an alarm journal query reports, the format is in days not hours, is it possible to format this within the report ?
the tag in question is active Duration from the alarm journal Query.
You don't mention it in your post, but it appears that you are trying to generate a report of an alarm journal. Is that correct? If so, you might edit the post to explain and add the reporting tag while you are at it.
I've never used alarm journals so I may not be much use in providiing a solution.
Welcome to the forum.
