I added the Activex Module into ignition. I have some other activex objects that I would like to use but can’t seem to figure out how to get them into Ignition. I added the generic activex control to the screen but cant see where to customize that.
I believe it is possible. If I remember correctly, when you want to add a custom activeX control, in the activex tab, there should e a general ActiveX addon object. I think you need the CLSID, but I have never even added an ActiveX control before. Just going off what I remember. Someone else will now more.
