I’m running Ignition 7.5.0 (b1079). I just installed the ActiveX Module 2.5.0.131.
When I try to add the pdf component I get this error “Error creating component” “IllegalStateException: OleObject is not created.”
Ignition v7.5.0 (b1079)
Java: Oracle Corporation 1.7.0_05
I get this same error when adding any of the ActiveX components.
Full error
java.lang.IllegalStateException: OleObject is not created.
at com.jniwrapper.win32.automation.OleContainer.doVerb(SourceFile:903)
at com.inductiveautomation.vision.activex.components.ActiveXComponent.showOleObject(ActiveXComponent.java:248)
at com.inductiveautomation.vision.activex.components.ActiveXComponent.doShowOleObject(ActiveXComponent.java:236)
at com.inductiveautomation.vision.activex.components.ActiveXComponent.access$000(ActiveXComponent.java:28)
at com.inductiveautomation.vision.activex.components.ActiveXComponent$1.ancestorAdded(ActiveXComponent.java:81)
at javax.swing.AncestorNotifier.fireAncestorAdded(Unknown Source)
at javax.swing.AncestorNotifier.propertyChange(Unknown Source)
at java.beans.PropertyChangeSupport.fire(Unknown Source)
at java.beans.PropertyChangeSupport.firePropertyChange(Unknown Source)
at java.awt.Component.firePropertyChange(Unknown Source)
at javax.swing.JComponent.addNotify(Unknown Source)
at java.awt.Container.addImpl(Unknown Source)
at java.awt.Container.add(Unknown Source)
at com.inductiveautomation.factorypmi.application.components.BasicContainer.privateAdd(BasicContainer.java:203)
at com.inductiveautomation.factorypmi.application.components.BasicContainer.addComponent(BasicContainer.java:177)
at com.inductiveautomation.factorypmi.designer.workspace.LayoutManipulator.add(LayoutManipulator.java:159)
at com.inductiveautomation.factorypmi.designer.workspace.WindowWorkspace.add(WindowWorkspace.java:954)
at com.inductiveautomation.factorypmi.designer.workspace.WindowWorkspace.add(WindowWorkspace.java:942)
at com.inductiveautomation.factorypmi.designer.workspace.WindowWorkspace$Delegate.addObject(WindowWorkspace.java:2971)
at com.inductiveautomation.factorypmi.designer.workspace.tools.InstantiationTool.onClick(InstantiationTool.java:97)
at com.inductiveautomation.ignition.designer.designable.DesignPanel$ToolMouseListener.onClick(DesignPanel.java:990)
at com.inductiveautomation.ignition.client.util.gui.CommonMouseAdapter.mouseReleased(CommonMouseAdapter.java:69)
at java.awt.AWTEventMulticaster.mouseReleased(Unknown Source)
at java.awt.Component.processMouseEvent(Unknown Source)
at javax.swing.JComponent.processMouseEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
at java.awt.Window.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.access$000(Unknown Source)
at java.awt.EventQueue$3.run(Unknown Source)
at java.security.ProtectionDomain$1.doIntersectionPrivilege(Unknown Source)
at java.awt.EventQueue$4.run(Unknown Source)
