I am using an AD/Database Hybrid user source for the project and according to the logs, the AD authentication and user roles queries are successful, but the client will not log in. Both methods of logging in are failing: manually typing in a username/password, and SSO.
The result is the same when using the user source authentication test on the gateway webpage.
I know AD is set up correctly because I am using an AD/Internal user source to log into the designer with SSO.
Here is the output of the Java Console:
Java Web Start 11.191.2.12 amd64
Using JRE version 1.8.0_191-b12 Java HotSpot(TM) 64-Bit Server VM
User home directory = C:\Users\robert.mosher
c: clear console window
f: finalize objects on finalization queue
g: garbage collect
h: display this help message
m: print memory usage
o: trigger logging
p: reload proxy configuration
q: hide console
r: reload policy configuration
s: dump system and deployment properties
t: dump thread list
v: dump thread stack
0-5: set trace level to <n>
Starting Bootstrap Loader v3.0
Connect Step [attempt 1] connecting to: http://192.168.2.40:8088/main...
Downloading manifest at http://192.168.2.40:8088/main/system/launchmf/C?os=windows&arch=x64
...connect successful
Successfully downloaded launch manifest:
<?xml version="1.0" encoding="UTF-8"?>
<launch scope="C">
<module name="" build="2018112821">
<jar name="java-cup-10k.jar" crc="AB682326" length="32451"/>
<jar name="commons-digester-1.8.1.jar" crc="20778438" length="42546"/>
<jar name="miglayout-core-4.2.jar" crc="EC3CFA11" length="29128"/>
<jar name="jide-components-3.7.2.jar" crc="51C571C7" length="104434"/>
<jar name="jide-plaf-3.7.2.jar" crc="5935398E" length="34343"/>
<jar name="common-7.9.10.jar" crc="B58BD9CB" length="904156"/>
<jar name="commons-logging-1.2.jar" crc="DB4B9A00" length="27460"/>
<jar name="commons-beanutils-1.8.3.jar" crc="86B560C6" length="61028"/>
<jar name="client-api-7.9.10.jar" crc="938DD878" length="901034"/>
<jar name="metrics-core-3.1.0.jar" crc="E8CF1893" length="26710"/>
<jar name="bcprov-jdk16-unsign-1.46.jar" crc="9AB21461" length="417043"/>
<jar name="commons-lang3-3.3.2.jar" crc="E7839394" length="137157"/>
<jar name="commons-collections-3.2.1.jar" crc="CFFAC520" length="114030"/>
<jar name="jul-to-slf4j-1.7.21.jar" crc="503F83A" length="2381"/>
<jar name="core-java6-3.2.1.4.jar" crc="E8500B4B" length="172935"/>
<jar name="jfreechart-min-1.0.0.jar" crc="B0BAA748" length="419001"/>
<jar name="commons-io-2.1.jar" crc="37C74DE0" length="51509"/>
<jar name="miglayout-swing-4.2.jar" crc="6D970370" length="6570"/>
<jar name="commons-cli-1.0.jar" crc="32913666" length="10867"/>
<jar name="barcode4j-2.1.jar" crc="94F89669" length="86119"/>
<jar name="jide-grids-3.7.2.jar" crc="BA25ADC0" length="545842"/>
<jar name="forms-1.0.7.jar" crc="A5617906" length="26156"/>
<jar name="guava-18.0.jar" crc="34EB2E0B" length="441989"/>
<jar name="jython-2.5.3-ia3.jar" crc="7649E30A" length="3678377"/>
<jar name="joda-time-2.3.jar" crc="C8E64FF1" length="167906"/>
<jar name="slf4j-api-1.7.21.jar" crc="ED827065" length="13921"/>
<jar name="gson-2.8.0.jar" crc="F814A00" length="53881"/>
<jar name="logback-classic-1.1.7.jar" crc="9DAED028" length="85290"/>
<jar name="alloy-1.4.4.ia1.jar" crc="F9EC2783" length="107335"/>
<jar name="active-query-builder-7.9.10.jar" crc="26A27C0C" length="664015"/>
<jar name="log4j-over-slf4j-1.7.21.jar" crc="DF2BDF66" length="6451"/>
<jar name="cron4j-2.2.3.jar" crc="433BD78" length="10242"/>
<jar name="commons-lang-1.0.jar" crc="66C5C0BA" length="21220"/>
<jar name="jide-common-3.7.2.jar" crc="D9A67661" length="427664"/>
<jar name="commons-math3-3.6.1.jar" crc="7F552947" length="594033"/>
<jar name="commons-validator-1.4.1.jar" crc="DE62627D" length="60038"/>
<jar name="logback-core-1.1.7.jar" crc="54C09D82" length="116933"/>
<jar name="launchclient.jar" crc="635B0C67" length="298008"/>
</module>
<module name="rept" build="2018112813">
<jar name="__1233934139__bcprov-ext-jdk15on-1.54.jar" crc="DB156DBA" length="840455"/>
<jar name="__1233934139__icepdf-viewer-6.1.3.jar" crc="CACBE926" length="385205"/>
<jar name="__1233934139__tools-jar-14.9.5.jar" crc="7D9A2343" length="1353619"/>
<jar name="__1233934139__reporting-common-4.9.10.jar" crc="9B85C34E" length="1285162"/>
<jar name="__1233934139__bcpkix-jdk15on-1.54.jar" crc="BF44A715" length="149508"/>
<jar name="__1233934139__icepdf-core-6.1.3.jar" crc="942F157D" length="772357"/>
<jar name="__1233934139__poi-3.14.jar" crc="960551FC" length="641921"/>
<jar name="__1233934139__reporting-client-4.9.10.jar" crc="DCC3B2A1" length="1291896"/>
<jar name="__1233934139__commons-codec-1.10.jar" crc="F6F29A02" length="92603"/>
<jar name="__1233934139__bcprov-jdk15on-1.54.jar" crc="B3C2A04D" length="816133"/>
</module>
<module name="xopc" build="2018112813">
<jar name="__1203188602__opc-ua-common-4.9.10.jar" crc="1755ADB7" length="370"/>
<jar name="__1203188602__opc-ua-client-4.9.10.jar" crc="6C5FA03B" length="2357"/>
</module>
<module name="com.inductiveautomation.alarm-notification" build="2018112813">
<jar name="__3648090672__alarm-notification-common-4.9.10.jar" crc="B5A59015" length="5808"/>
<jar name="__3648090672__alarm-notification-client-4.9.10.jar" crc="6F587FB7" length="14242"/>
</module>
<module name="fpmi" build="2018112813">
<jar name="__765785812__commons-logging-1.1.1.jar" crc="4B09A5F" length="26691"/>
<jar name="__765785812__httpclient-4.2.6.jar" crc="99F0E8E7" length="101082"/>
<jar name="__765785812__commons-codec-1.6.jar" crc="D4695169" length="72115"/>
<jar name="__765785812__httpcore-4.2.5.jar" crc="4C5EB242" length="60946"/>
<jar name="__765785812__vision-common-9.9.10.jar" crc="14BF310C" length="2081"/>
<jar name="__765785812__vision-client-9.9.10.jar" crc="B31BF5C6" length="815423"/>
</module>
<module name="com.inductiveautomation.sfc" build="2018112821">
<jar name="__323776056__sfc-client-3.9.10.jar" crc="2E2E340E" length="39015"/>
<jar name="__323776056__sfc-common-3.9.10.jar" crc="296AFAB6" length="34695"/>
</module>
<module name="mobile" build="2018112821">
<jar name="__3963167437__mobile-client-4.9.10.jar" crc="54837343" length="1850"/>
<jar name="__3963167437__mobile-common-4.9.10.jar" crc="A8717991" length="2838"/>
</module>
<module name="fsql" build="2018112821">
<jar name="__3502128348__sql-bridge-common-8.9.10.jar" crc="24C808A8" length="25236"/>
</module>
<module name="com.inductiveautomation.eam" build="2018112813">
<jar name="__654820924__eam-client-2.9.10.jar" crc="319348B1" length="2287"/>
<jar name="__654820924__eam-common-2.9.10.jar" crc="3A1E13B3" length="2348"/>
</module>
<module name="dnp3-driver" build="2018112813">
<jar name="__394611185__dnp3-client-2.9.10.jar" crc="3B3FC215" length="2014"/>
<jar name="__394611185__dnp3-common-2.9.10.jar" crc="9AB97BB3" length="566"/>
</module>
<thirdPartyModules md5="9e5b066b037adf9090cf78603e0ac9ee"/>
</launch>
Claiming id in C:\Users\robert.mosher\.ignition\cache\gw192.168.2.40_8088_8043_main...
... obtaining lock
... lock obtained.
... claimed id 0
Calculated necessary downloads:
<launch scope="C">
</module>
</module>
</module>
</module>
</module>
</module>
</module>
</module>
</module>
</module>
<thirdPartyModules md5="null"/>
</launch>
Third party Python modules downloaded.
Successfully read project CPAcesInventory.proj from cache. Edit Count = 730, UUID = 81fad40a-b5aa-ecc9-acc7-b24619e7d9df
Cache file CPAcesInventory.proj loaded sucessfully from cache, downloading diff...
Downloading "http://192.168.2.40:8088/main/system/project/C/P/730/81fad40a-b5aa-ecc9-acc7-b24619e7d9df/AcesInventory"...
Connect successful.
Starting download of 1,951 bytes
Download successful
Successfully read project CP_global_.proj from cache. Edit Count = 0, UUID = fb64e026-adfa-1291-1612-fe12cdaa61f6
Cache file CP_global_.proj loaded sucessfully from cache, downloading diff...
Downloading "http://192.168.2.40:8088/main/system/project/C/P/0/fb64e026-adfa-1291-1612-fe12cdaa61f6/[global]"...
Connect successful.
Starting download of 325 bytes
Download successful
Downloading "http://192.168.2.40:8088/main/system/translations/"...
Connect successful.
Starting download of 428 bytes
Download successful
Creating classloader with JAR files: [file:/C:/Users/robert.mosher/.ignition/cache/resources/platform/java-cup-10k.jar/00000000AB682326/java-cup-10k.jar, file:/C:/Users/robert.mosher/.ignition/cache/resources/platform/commons-digester-1.8.1.jar/0000000020778438/commons-digester-1.8.1.jar, file:/C:/Users/robert.mosher/.ignition/cache/resources/platform/miglayout-core-4.2.jar/00000000EC3CFA11/miglayout-core-4.2.jar, file:/C:/Users/robert.mosher/.ignition/cache/resources/platform/jide-components-3.7.2.jar/0000000051C571C7/jide-components-3.7.2.jar, file:/C:/Users/robert.mosher/.ignition/cache/resources/platform/jide-plaf-3.7.2.jar/000000005935398E/jide-plaf-3.7.2.jar, file:/C:/Users/robert.mosher/.ignition/cache/resources/platform/common-7.9.10.jar/00000000B58BD9CB/common-7.9.10.jar, file:/C:/Users/robert.mosher/.ignition/cache/resources/platform/commons-logging-1.2.jar/00000000DB4B9A00/commons-logging-1.2.jar, file:/C:/Users/robert.mosher/.ignition/cache/resources/platform/commons-beanutils-1.8.3.jar/0000000086B560C6/commons-beanutils-1.8.3.jar, file:/C:/Users/robert.mosher/.ignition/cache/resources/platform/client-api-7.9.10.jar/00000000938DD878/client-api-7.9.10.jar, file:/C:/Users/robert.mosher/.ignition/cache/resources/platform/metrics-core-3.1.0.jar/00000000E8CF1893/metrics-core-3.1.0.jar, file:/C:/Users/robert.mosher/.ignition/cache/resources/platform/bcprov-jdk16-unsign-1.46.jar/000000009AB21461/bcprov-jdk16-unsign-1.46.jar, file:/C:/Users/robert.mosher/.ignition/cache/resources/platform/commons-lang3-3.3.2.jar/00000000E7839394/commons-lang3-3.3.2.jar, file:/C:/Users/robert.mosher/.ignition/cache/resources/platform/commons-collections-3.2.1.jar/00000000CFFAC520/commons-collections-3.2.1.jar, file:/C:/Users/robert.mosher/.ignition/cache/resources/platform/jul-to-slf4j-1.7.21.jar/000000000503F83A/jul-to-slf4j-1.7.21.jar, file:/C:/Users/robert.mosher/.ignition/cache/resources/platform/core-java6-3.2.1.4.jar/00000000E8500B4B/core-java6-3.2.1.4.jar, file:/C:/Users/robert.mosher/.ignition/cache/resources/platform/jfreechart-min-1.0.0.jar/00000000B0BAA748/jfreechart-min-1.0.0.jar, file:/C:/Users/robert.mosher/.ignition/cache/resources/platform/commons-io-2.1.jar/0000000037C74DE0/commons-io-2.1.jar, file:/C:/Users/robert.mosher/.ignition/cache/resources/platform/miglayout-swing-4.2.jar/000000006D970370/miglayout-swing-4.2.jar, file:/C:/Users/robert.mosher/.ignition/cache/resources/platform/commons-cli-1.0.jar/0000000032913666/commons-cli-1.0.jar, file:/C:/Users/robert.mosher/.ignition/cache/resources/platform/barcode4j-2.1.jar/0000000094F89669/barcode4j-2.1.jar, file:/C:/Users/robert.mosher/.ignition/cache/resources/platform/jide-grids-3.7.2.jar/00000000BA25ADC0/jide-grids-3.7.2.jar, file:/C:/Users/robert.mosher/.ignition/cache/resources/platform/forms-1.0.7.jar/00000000A5617906/forms-1.0.7.jar, file:/C:/Users/robert.mosher/.ignition/cache/resources/platform/guava-18.0.jar/0000000034EB2E0B/guava-18.0.jar, file:/C:/Users/robert.mosher/.ignition/cache/resources/platform/jython-2.5.3-ia3.jar/000000007649E30A/jython-2.5.3-ia3.jar, file:/C:/Users/robert.mosher/.ignition/cache/resources/platform/joda-time-2.3.jar/00000000C8E64FF1/joda-time-2.3.jar, file:/C:/Users/robert.mosher/.ignition/cache/resources/platform/slf4j-api-1.7.21.jar/00000000ED827065/slf4j-api-1.7.21.jar, file:/C:/Users/robert.mosher/.ignition/cache/resources/platform/gson-2.8.0.jar/000000000F814A00/gson-2.8.0.jar, file:/C:/Users/robert.mosher/.ignition/cache/resources/platform/logback-classic-1.1.7.jar/000000009DAED028/logback-classic-1.1.7.jar, file:/C:/Users/robert.mosher/.ignition/cache/resources/platform/alloy-1.4.4.ia1.jar/00000000F9EC2783/alloy-1.4.4.ia1.jar, file:/C:/Users/robert.mosher/.ignition/cache/resources/platform/active-query-builder-7.9.10.jar/0000000026A27C0C/active-query-builder-7.9.10.jar, file:/C:/Users/robert.mosher/.ignition/cache/resources/platform/log4j-over-slf4j-1.7.21.jar/00000000DF2BDF66/log4j-over-slf4j-1.7.21.jar, file:/C:/Users/robert.mosher/.ignition/cache/resources/platform/cron4j-2.2.3.jar/000000000433BD78/cron4j-2.2.3.jar, file:/C:/Users/robert.mosher/.ignition/cache/resources/platform/commons-lang-1.0.jar/0000000066C5C0BA/commons-lang-1.0.jar, file:/C:/Users/robert.mosher/.ignition/cache/resources/platform/jide-common-3.7.2.jar/00000000D9A67661/jide-common-3.7.2.jar, file:/C:/Users/robert.mosher/.ignition/cache/resources/platform/commons-math3-3.6.1.jar/000000007F552947/commons-math3-3.6.1.jar, file:/C:/Users/robert.mosher/.ignition/cache/resources/platform/commons-validator-1.4.1.jar/00000000DE62627D/commons-validator-1.4.1.jar, file:/C:/Users/robert.mosher/.ignition/cache/resources/platform/logback-core-1.1.7.jar/0000000054C09D82/logback-core-1.1.7.jar, file:/C:/Users/robert.mosher/.ignition/cache/resources/modules/rept/__1233934139__bcprov-ext-jdk15on-1.54.jar/00000000DB156DBA/__1233934139__bcprov-ext-jdk15on-1.54.jar, file:/C:/Users/robert.mosher/.ignition/cache/resources/modules/rept/__1233934139__icepdf-viewer-6.1.3.jar/00000000CACBE926/__1233934139__icepdf-viewer-6.1.3.jar, file:/C:/Users/robert.mosher/.ignition/cache/resources/modules/rept/__1233934139__tools-jar-14.9.5.jar/000000007D9A2343/__1233934139__tools-jar-14.9.5.jar, file:/C:/Users/robert.mosher/.ignition/cache/resources/modules/rept/__1233934139__reporting-common-4.9.10.jar/000000009B85C34E/__1233934139__reporting-common-4.9.10.jar, file:/C:/Users/robert.mosher/.ignition/cache/resources/modules/rept/__1233934139__bcpkix-jdk15on-1.54.jar/00000000BF44A715/__1233934139__bcpkix-jdk15on-1.54.jar, file:/C:/Users/robert.mosher/.ignition/cache/resources/modules/rept/__1233934139__icepdf-core-6.1.3.jar/00000000942F157D/__1233934139__icepdf-core-6.1.3.jar, file:/C:/Users/robert.mosher/.ignition/cache/resources/modules/rept/__1233934139__poi-3.14.jar/00000000960551FC/__1233934139__poi-3.14.jar, file:/C:/Users/robert.mosher/.ignition/cache/resources/modules/rept/__1233934139__reporting-client-4.9.10.jar/00000000DCC3B2A1/__1233934139__reporting-client-4.9.10.jar, file:/C:/Users/robert.mosher/.ignition/cache/resources/modules/rept/__1233934139__commons-codec-1.10.jar/00000000F6F29A02/__1233934139__commons-codec-1.10.jar, file:/C:/Users/robert.mosher/.ignition/cache/resources/modules/rept/__1233934139__bcprov-jdk15on-1.54.jar/00000000B3C2A04D/__1233934139__bcprov-jdk15on-1.54.jar, file:/C:/Users/robert.mosher/.ignition/cache/resources/modules/xopc/__1203188602__opc-ua-common-4.9.10.jar/000000001755ADB7/__1203188602__opc-ua-common-4.9.10.jar, file:/C:/Users/robert.mosher/.ignition/cache/resources/modules/xopc/__1203188602__opc-ua-client-4.9.10.jar/000000006C5FA03B/__1203188602__opc-ua-client-4.9.10.jar, file:/C:/Users/robert.mosher/.ignition/cache/resources/modules/com.inductiveautomation.alarm-notification/__3648090672__alarm-notification-common-4.9.10.jar/00000000B5A59015/__3648090672__alarm-notification-common-4.9.10.jar, file:/C:/Users/robert.mosher/.ignition/cache/resources/modules/com.inductiveautomation.alarm-notification/__3648090672__alarm-notification-client-4.9.10.jar/000000006F587FB7/__3648090672__alarm-notification-client-4.9.10.jar, file:/C:/Users/robert.mosher/.ignition/cache/resources/modules/fpmi/__765785812__commons-logging-1.1.1.jar/0000000004B09A5F/__765785812__commons-logging-1.1.1.jar, file:/C:/Users/robert.mosher/.ignition/cache/resources/modules/fpmi/__765785812__httpclient-4.2.6.jar/0000000099F0E8E7/__765785812__httpclient-4.2.6.jar, file:/C:/Users/robert.mosher/.ignition/cache/resources/modules/fpmi/__765785812__commons-codec-1.6.jar/00000000D4695169/__765785812__commons-codec-1.6.jar, file:/C:/Users/robert.mosher/.ignition/cache/resources/modules/fpmi/__765785812__httpcore-4.2.5.jar/000000004C5EB242/__765785812__httpcore-4.2.5.jar, file:/C:/Users/robert.mosher/.ignition/cache/resources/modules/fpmi/__765785812__vision-common-9.9.10.jar/0000000014BF310C/__765785812__vision-common-9.9.10.jar, file:/C:/Users/robert.mosher/.ignition/cache/resources/modules/fpmi/__765785812__vision-client-9.9.10.jar/00000000B31BF5C6/__765785812__vision-client-9.9.10.jar, file:/C:/Users/robert.mosher/.ignition/cache/resources/modules/com.inductiveautomation.sfc/__323776056__sfc-client-3.9.10.jar/000000002E2E340E/__323776056__sfc-client-3.9.10.jar, file:/C:/Users/robert.mosher/.ignition/cache/resources/modules/com.inductiveautomation.sfc/__323776056__sfc-common-3.9.10.jar/00000000296AFAB6/__323776056__sfc-common-3.9.10.jar, file:/C:/Users/robert.mosher/.ignition/cache/resources/modules/mobile/__3963167437__mobile-client-4.9.10.jar/0000000054837343/__3963167437__mobile-client-4.9.10.jar, file:/C:/Users/robert.mosher/.ignition/cache/resources/modules/mobile/__3963167437__mobile-common-4.9.10.jar/00000000A8717991/__3963167437__mobile-common-4.9.10.jar, file:/C:/Users/robert.mosher/.ignition/cache/resources/modules/fsql/__3502128348__sql-bridge-common-8.9.10.jar/0000000024C808A8/__3502128348__sql-bridge-common-8.9.10.jar, file:/C:/Users/robert.mosher/.ignition/cache/resources/modules/com.inductiveautomation.eam/__654820924__eam-client-2.9.10.jar/00000000319348B1/__654820924__eam-client-2.9.10.jar, file:/C:/Users/robert.mosher/.ignition/cache/resources/modules/com.inductiveautomation.eam/__654820924__eam-common-2.9.10.jar/000000003A1E13B3/__654820924__eam-common-2.9.10.jar, file:/C:/Users/robert.mosher/.ignition/cache/resources/modules/dnp3-driver/__394611185__dnp3-client-2.9.10.jar/000000003B3FC215/__394611185__dnp3-client-2.9.10.jar, file:/C:/Users/robert.mosher/.ignition/cache/resources/modules/dnp3-driver/__394611185__dnp3-common-2.9.10.jar/000000009AB97BB3/__394611185__dnp3-common-2.9.10.jar]
Starting class: com.inductiveautomation.factorypmi.application.runtime.ClientLaunchHook
10:35:51.947 [Thread-10] INFO com.inductiveautomation.factorypmi.application.runtime.ClientLaunchHook - Ignition Client v7.9.10 (b2018112821)
10:35:52.745 [Thread-10] INFO Localization.ClientLocalizationManager - Translation term database initialized successfully
10:35:52.761 [Thread-10] INFO com.inductiveautomation.ignition.client.gateway_interface.GatewayConnectionManager - Initializing gateway connection with URLs: [http://192.168.2.40:8088/main]
10:35:52.839 [Thread-10] INFO com.inductiveautomation.ignition.client.util.gui.progress.ClientProgressManager - Progress manager started.
10:35:53.582 [Thread-10] ERROR com.inductiveautomation.factorypmi.application.runtime.ClientLaunchHook - AD SSO login failed.
com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Login failed.
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.newGatewayException(GatewayInterface.java:341)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:315)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:268)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.invoke(GatewayInterface.java:894)
at com.inductiveautomation.factorypmi.application.runtime.ClientGatewayConnection.doLogin(ClientGatewayConnection.java:93)
at com.inductiveautomation.ignition.client.gateway_interface.AbstractGatewayConnection.login(AbstractGatewayConnection.java:891)
at com.inductiveautomation.factorypmi.application.runtime.ClientLaunchHook$AutoLoginDelegate.loginAdSso(ClientLaunchHook.java:371)
at com.inductiveautomation.factorypmi.application.runtime.ClientLaunchHook$AutoLoginDelegate.authenticate(ClientLaunchHook.java:291)
at com.inductiveautomation.factorypmi.application.runtime.ClientLaunchHook.setup(ClientLaunchHook.java:263)
at com.inductiveautomation.ignition.client.launch.steps.StartupStep.run(StartupStep.java:114)
at com.inductiveautomation.ignition.client.launch.AbstractStepRunner.run(AbstractStepRunner.java:33)
at java.lang.Thread.run(Unknown Source)
Caused by: com.inductiveautomation.ignition.client.gateway_interface.GatewayResponse$GatewayThrowable: Login failed.
at com.inductiveautomation.ignition.gateway.servlets.gateway.functions.Login.client(Login.java:124)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at com.inductiveautomation.ignition.gateway.servlets.gateway.AbstractGatewayFunction.invoke(AbstractGatewayFunction.java:208)
at com.inductiveautomation.ignition.gateway.servlets.Gateway.doPost(Gateway.java:404)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
at com.inductiveautomation.ignition.gateway.bootstrap.MapServlet.service(MapServlet.java:85)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:837)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:583)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:226)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1160)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:511)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1092)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
at org.eclipse.jetty.server.handler.HandlerList.handle(HandlerList.java:52)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:134)
at org.eclipse.jetty.server.Server.handle(Server.java:518)
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:308)
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:244)
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:273)
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:95)
at org.eclipse.jetty.io.SelectChannelEndPoint$2.run(SelectChannelEndPoint.java:93)
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.produceAndRun(ExecuteProduceConsume.java:246)
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.run(ExecuteProduceConsume.java:156)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:654)
at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:572)
at java.lang.Thread.run(Thread.java:748)
Creating frame. extendedState=6, bounds=java.awt.Rectangle[x=0,y=0,width=1920,height=1080]
After some experimenting with other users I found that it is just my username that will not authenticate. All other users that I have tried are working fine. I have been testing with just my username while trying different queries and setting up the user source. Is there a cache somewhere that I need to clear?
