AD Error fetching roles and users. AD/Hybrid does it just fine
Hi everyone,
I have an AD and an AD/Hybrid user source set up. I am able to verify both user sources, and when verifying the AD one I get my account’s role information returned. When I click “manage users” on the hybrid source, I get all the users after a few seconds. However, whenever I click “manage users” on the AD source, no users or roles are returned. In the logs, I repeatedly get an error fetching the roles and users for the AD profile. The account used for LDAP gateway authentication’s username is “Srvc_IgnitionHUN”. According to this thread, a period in the username was affecting the login. Could the underscore be causing the issue?
Below is the error from the logs:
javax.naming.AuthenticationException: [LDAP: error code 49 - 80090308: LdapErr: DSID-0C090439, comment: AcceptSecurityContext error, data 52e, v4563]
at java.naming/com.sun.jndi.ldap.LdapCtx.mapErrorCode(Unknown Source)
at java.naming/com.sun.jndi.ldap.LdapCtx.processReturnCode(Unknown Source)
at java.naming/com.sun.jndi.ldap.LdapCtx.connect(Unknown Source)
at java.naming/com.sun.jndi.ldap.LdapCtx.(Unknown Source)
at java.naming/com.sun.jndi.ldap.LdapCtxFactory.getLdapCtxFromUrl(Unknown Source)
at java.naming/com.sun.jndi.ldap.LdapCtxFactory.getUsingURL(Unknown Source)
at java.naming/com.sun.jndi.ldap.LdapCtxFactory.getUsingURLs(Unknown Source)
at java.naming/com.sun.jndi.ldap.LdapCtxFactory.getLdapCtxInstance(Unknown Source)
at java.naming/com.sun.jndi.ldap.LdapCtxFactory.getInitialContext(Unknown Source)
at java.naming/javax.naming.spi.NamingManager.getInitialContext(Unknown Source)
at java.naming/javax.naming.InitialContext.getDefaultInitCtx(Unknown Source)
at java.naming/javax.naming.InitialContext.init(Unknown Source)
at java.naming/javax.naming.ldap.InitialLdapContext.(Unknown Source)
at com.inductiveautomation.ignition.gateway.authentication.impl.LDAPHelper.openContext(LDAPHelper.java:276)
at com.inductiveautomation.ignition.gateway.authentication.impl.LDAPHelper.search(LDAPHelper.java:339)
at com.inductiveautomation.ignition.gateway.authentication.impl.ActiveDirectoryUserSource.getRoles(ActiveDirectoryUserSource.java:276)
at com.inductiveautomation.ignition.gateway.authentication.UserSourceWrapper.doGetRoles(UserSourceWrapper.java:424)
at com.inductiveautomation.ignition.gateway.authentication.UserSourceWrapper$RoleCacheImpl.doUpdate(UserSourceWrapper.java:305)
at com.inductiveautomation.ignition.gateway.authentication.UserSourceWrapper$RoleCacheImpl.doUpdate(UserSourceWrapper.java:300)
at com.inductiveautomation.ignition.gateway.authentication.AbstractCache$UpdateTask.run(AbstractCache.java:118)
Any help would be appreciated. Thanks.
When I look up this error code (49 / 52e) the information I find is:
Returns when username is valid but password/credential is invalid.
source: https://ldapwiki.com/wiki/Common%20Active%20Directory%20Bind%20Errors
Thanks for the source. I was not given the password, so I will reach out to the customer to have them verify.
If the password is incorrect, shouldn’t I not be able to verify the user source?
When you verify a user on a user source you’re using the username/password you type into the verification page.
The action you’re seeing fail is using the credentials configured on the profile as “Gateway Username” and “Password”.
Got it. Thanks for the explanation.
I'm getting the same error code (49). The link from the AD and Ignition was lost because the user passwords were reset.
This has happened twice. When I reset the passwords all my users come back.
The user does not know how to do this.
I'm not resetting the AD user passwords.
I confirmed with IT that it's not them.
So what can be possibly doing this?
What's the subcode / full error?
See picture attached.
UPDATE
I reset the AD Password and all accounts came back.
Also all accounts password were reset as well.
Sorry, gonna need you to actually copy and paste the whole thing.
Here you go.
javax.naming.AuthenticationException: [LDAP: error code 49 - 80090308: LdapErr: DSID-0C090453, comment: AcceptSecurityContext error, data 532, v3839]
at com.sun.jndi.ldap.LdapCtx.mapErrorCode(Unknown Source)
at com.sun.jndi.ldap.LdapCtx.processReturnCode(Unknown Source)
at com.sun.jndi.ldap.LdapCtx.connect(Unknown Source)
at com.sun.jndi.ldap.LdapCtx.(Unknown Source)
at com.sun.jndi.ldap.LdapCtxFactory.getUsingURL(Unknown Source)
at com.sun.jndi.ldap.LdapCtxFactory.getUsingURLs(Unknown Source)
at com.sun.jndi.ldap.LdapCtxFactory.getLdapCtxInstance(Unknown Source)
at com.sun.jndi.ldap.LdapCtxFactory.getInitialContext(Unknown Source)
at javax.naming.spi.NamingManager.getInitialContext(Unknown Source)
at javax.naming.InitialContext.getDefaultInitCtx(Unknown Source)
at javax.naming.InitialContext.init(Unknown Source)
at javax.naming.ldap.InitialLdapContext.(Unknown Source)
**at com.inductiveautomation.ignition.gateway.authentication.impl.LDAPHelper.openContext(LDAPHelper.java:207)**
at com.inductiveautomation.ignition.gateway.authentication.impl.LDAPHelper.search(LDAPHelper.java:270)
at com.inductiveautomation.ignition.gateway.authentication.impl.ADInternalHybridUserSource.getUsers(ADInternalHybridUserSource.java:166)
at com.inductiveautomation.ignition.gateway.authentication.UserSourceWrapper.updateCache(UserSourceWrapper.java:120)
at com.inductiveautomation.ignition.gateway.authentication.UserSourceWrapper.getUsers(UserSourceWrapper.java:95)
... snipped by moderator ...
49 / 532 means the passwords are expiring. Talk to whoever manages your AD instance.
