I’m using the latest version of the ad hoc trend resource with 8.1.18.
I define some chart in a db without problem. but if i try to load this chart, the first time it doesn’t work. I see in the props that everything is loaded correctly in axes, plots,… when a this is done if i try to call another trending saved in the database, this is working perfectly every times. Until i change from view and i come back to my ad Hoc trend view. I have the same behavior when using the load from file function.
Is there a ways to refresh the trend at load?
The trend is also refreshing is i drag and drop a pen from the browser into the trending. Then i have the trending loaded from the database/file and the pen i’ve dropped.
Regards
