AD Hybrid Setup Question
Hello,
We are using an AD hybrid user source, with a soft failover to an internal user source. I have noticed that the roles session property is properly populated when a user in the internal group logs in but it is null when an AD user logs in. Roles are assigned properly to the AD users. Any ideas on why I am seeing this behavior?
Thanks,
Frank
Have you tried enabling the 'Populate Users On-Demand' setting in the AD/Internal Hybrid settings? I think I remember running into a similar issue and with that setting enabled user roles showed up as expected, maybe it will work for you.
