Add 2 dataset values and put in single dataset
You should use is None instead of == None, it prevents unexpected behavior when comparing things for which the equality operator has been overridden.
It’s also faster !
The dataset is constructed with the types you want, but the actual data is still Dates. You now have to iterate through your data to cast it to the types you want to use. The DatasetBuilder class mentioned earlier in this thread would help there.
EDIT: fixed error in the constructor lines.
from com.inductiveautomation.ignition.common import DatasetBuilder
from java.lang import String, Integer, Long, Boolean, Float
ds11 = system.tag.queryTagHistory(paths=[
"[MQTT Engine]Edge Nodes/VaujoursV5/Line/Takeoff/Takeoff_/DET/DET 1/Production Data/Deck Number"
			startDate='2022-08-31 22:00:00', endDate='2022-08-31 22:00:10',returnSize=-1,  aggregationMode="MinMax", returnFormat='Wide',noInterpolation = False)
builder = DatasetBuilder.newBuilder()
builder.colNames(['date','H01'])
builder.colTypes([String, Float])
for row in system.dataset.toPyDataSet(ds11)
	builder.addRow([system.date.format(row[0], "yyyy-MM-dd HH:mm:ss"), row[1]])
data1 = builder.build()
if i want to convert Double column type to string means what i have to do in this line?
builder.addRow([system.date.format(row[0], “yyyy-MM-dd HH:mm:ss”), row[1]])
What column is a Double?
[class java.lang.Double]
i am getting this type for one column in my dataset
For that i want to convert it to string column type
Is it the date column, or is it a value?
value column that’s why i am asking
str(row[1])
builder.addRow([str(row[1])])
like this?
You need an item for each column in the row. Assuming there is a date and a value for each row, and you want a string for each of them:
builder.addRow([system.date.format(row[0], "yyyy-MM-dd HH:mm:ss"), str(row[1])])
one error i am getting
  File "<input>", line 22, in <module>
NameError: name 'builder' is not defined
Show your code. I can’t quite read it from here.
As a guess, I’m betting you’re missing something like:
from com.inductiveautomation.ignition.common.util import DatasetBuilder
print ds11
builder.colNames = ['date','H01']
builder.colTypes = [String, Float]
for row in system.dataset.toPyDataSet(ds11):
error
  File "<input>", line 36, in <module>
TypeError: readonly attribute
for this line i am getting **builder.colNames = [‘date’,‘H01’]**
.colNames and .colTypes are methods, not properties. You are trying to assign to them. That is incorrect. Look at Jordan’s examples again. { Edit: grumble. Didn’t expect Jordan to screw that up. }
Whoops! Been a while since I’ve used it. Try:
That one really was on me. :roll_eyes:
EDIT: fixed code above.
getting error for this line when i try to convert double to string
 File "<event:mouseClicked>", line 38, in <module>
TypeError: format(): 1st arg can't be coerced to java.util.Date
	at org.python.core.Py.TypeError(Py.java:236)
	at org.python.core.PyReflectedFunction.throwError(PyReflectedFunction.java:213)
	at org.python.core.PyReflectedFunction.throwBadArgError(PyReflectedFunction.java:316)
	at org.python.core.PyReflectedFunction.throwError(PyReflectedFunction.java:325)
	at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:171)
	at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:208)
	at org.python.core.PyObject.__call__(PyObject.java:477)
	at org.python.core.PyObject.__call__(PyObject.java:481)
	at org.python.pycode._pyx530.f$0(<event:mouseClicked>:48)
	at org.python.pycode._pyx530.call_function(<event:mouseClicked>)
	at org.python.core.PyTableCode.call(PyTableCode.java:173)
	at org.python.core.Py.runCode(Py.java:1687)
	at com.inductiveautomation.ignition.common.script.ScriptManager.runCode(ScriptManager.java:788)
	at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.runActions(ActionAdapter.java:206)
	at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.invoke(ActionAdapter.java:299)
	at com.inductiveautomation.factorypmi.application.binding.action.RelayInvocationHandler.invoke(RelayInvocationHandler.java:57)
	at com.sun.proxy.$Proxy55.mouseClicked(Unknown Source)
	at java.desktop/java.awt.AWTEventMulticaster.mouseClicked(Unknown Source)
	at java.desktop/java.awt.EventQueue$5.run(Unknown Source)
Caused by: org.python.core.PyException: TypeError: format(): 1st arg can't be coerced to java.util.Date
	... 49 common frames omitted
17:31:32.375 [EDT-Watchdog-1] INFO edt-watchdog - Non-responsive UI thread detected. Stack saved at 'C:\Users\P5178201\.ignition\cache\gwmetriks-eur001.saint-gobain.com_443\C0\NonResponsiveEdt-2022-09-01_173130.json'
17:32:30.307 [EDT-Watchdog-1] INFO edt-watchdog - Non-responsive UI thread detected. Stack saved at 'C:\Users\P5178201\.ignition\cache\gwmetriks-eur001.saint-gobain.com_443\C0\NonResponsiveEdt-2022-09-01_173230.json'
type i am getting
[class java.lang.Double, class java.lang.Double, class java.lang.Double, class java.lang.Double, class java.lang.Double, class java.lang.Double, class java.lang.Double, class java.lang.Double, class java.lang.Double, class java.lang.Double, class java.lang.Double, class java.lang.Double, class java.lang.Double, class java.lang.Double, class java.lang.Double, class java.lang.Double, class java.lang.Double, class java.lang.Double, class java.lang.Double, class java.lang.Double, class java.lang.Double, class java.lang.Double, class java.lang.Double, class java.lang.Double, class java.lang.Double, class java.lang.Double, class java.lang.Double, class java.lang.Double, class java.lang.Double, class java.lang.Double, class java.lang.Double, class java.lang.Double, class java.lang.Double, class java.lang.Double, class java.lang.Double, class java.lang.Double, class java.lang.Double]
my code
builder.colNames(["Deck_no", "H01", "H02", "H03", "H04", "H05", "H06", "H07", "H08", "H09", "H10", "H11", "H12", "H13", "H14", "H15", "H16", "H17","H18", "H19", "H20",
"H21", "H22", "H23", "H24", "H25", "H26", "H27", "H28", "H29", "H30", "H31", "H32", "H33", "H34", "H35", "H36"])
builder.colTypes([String, Integer, Integer, Integer, Integer, Integer, Integer, Integer,Integer, Integer, Integer, Integer, Integer, Integer, Integer, Integer, Integer, Integer,Integer, Integer, Integer,
Integer, Integer, Integer, Integer, Integer, Integer, Integer,Integer, Integer, Integer,Integer, Integer, Integer, Integer, Integer, Integer, Integer])
for row in system.dataset.toPyDataSet(filteredData):
event.source.parent.getComponent('Power Table').data = data1
Gotcha. Is Deck_no the timestamp, then? And then everything else is okay?
no its not time stamp
type is
double only for all columns
All right. I think we need to back up a moment, as we started out with a date a few posts ago, and now we’re not.
Does filteredData have the same columns as what will be shown in the power table? If not, what are the differences?
