Add 2 dataset values and put in single dataset
yes same column
[class java.lang.Double, class java.lang.Double, class java.lang.Double, class java.lang.Double, class java.lang.Double, class java.lang.Double, class java.lang.Double, class java.lang.Double, class java.lang.Double, class java.lang.Double, class java.lang.Double, class java.lang.Double, class java.lang.Double, class java.lang.Double, class java.lang.Double, class java.lang.Double, class java.lang.Double, class java.lang.Double, class java.lang.Double, class java.lang.Double, class java.lang.Double, class java.lang.Double, class java.lang.Double, class java.lang.Double, class java.lang.Double, class java.lang.Double, class java.lang.Double, class java.lang.Double, class java.lang.Double, class java.lang.Double, class java.lang.Double, class java.lang.Double, class java.lang.Double, class java.lang.Double, class java.lang.Double, class java.lang.Double, class java.lang.Double]
i want deck_no - that is first column filter data to be converted to string that’s it
In filter dataset - 14R*37C i have
i want first column to be converted to string that only i want
let's make this a bit more eye-friendly:
colNames = ["Deck_no"] + ["H{:02}".format(x) for x in xrange(1, 37)]
colTypes = [String] + [Integer]*37
Psst, guys:
https://docs.inductiveautomation.com/display/DOC81/system.dataset.formatDates
