We would like to create a window where the user at run can decide which controls/template are displayed.
We want to mimic the android home screen where you can select the widget to add.
Is there a way to add and parametrize controls/templates via script?
If not, is there another way to reach this same functionality?
I’ve seen this done with what we have available today. The idea is to model the different controls you want as templates, and then make a screen that is a grid of template instances. Then use whatever mechanism you want to allow the user to control which template is loaded in which spot. Pretty straight-forward, and it’s a graceful way of making the screen dynamic at runtime.
I was thinking of a presentation that one of our customers did at our Community Conference last year. I’ll have to see if I can send you the materials or not.
