Hello guys!
Is possible to add a new cursor to the chart module of Ignition ( not easy chart)
I need have two cursors in the chart
IF is possible there anyone can write me a example?
Thank you very much
Andrea
Hello guys!
Thank you very much
Andrea
You can change to any of the existing cursors by changing the value of:
event.source.cursorCode
Edit: If you mean 2 cursors at the same time then ![]()
Hi Johnson
Maybe I described my needs badly.
I need to add another vertical cursor to the chart , to pick two different points in the same pen ( see picture)
Is possible?
Thanks a lot
Andrea
Ooo! That’s a very good idea. Would make it very easy to work with custom time spans. I’ll have to add this to the NoteChart module I recently published.
Hi
Notechart module!??
Can you give me a link to download it?
Best regards
Andrea
NoteChart Module. If you don’t actually need the pen value display for both X-Traces, the module can already do what you want with one or more dynamically generated annotations.
Also see the announcement forum thread.
