Add buttons in header
Hi team,
Is it possible to add a button/buttons in the table header?
As we have Row# Order etc.
I typically use flex containers, so in this case, you add the position key under the button's style and set it as absolute. Then you can add height, width, left, right, top, and bottom keys to position it.
Depending on your container nesting, many times you need to add position:relative to the parent container so the button is positioned according to the parent and not root.
The other option is using an xy coordinate container.
What would these buttons do ?
You can put the table in a coordinate container and place a button on top of it, but it will be entirely unrelated to the table. You'll have to handle their behavior yourself.
