Add ' character to where clause
For some reason I can’t figure out how to enclose a tag with ‘ ‘ for the where clause in a BLOCK transaction.
I can put Code= ‘0001C’ and that works
but I can’t figure out what combination will do
Where the value of the tag {tag} = ‘0001C’
Code=‘{tag}’
Code={tag}
incorrect syntax near ‘C’
I’ve tried:
Code= “‘“ + {tag} + “‘“
Code= ‘‘‘‘ + {tag} + ‘‘‘‘
Code= concat(“‘“, {tag}, “‘“)
Code= concat(str(‘), {tag}, str(‘))
Code= concat(char(39), {tag}, char(39))
edited for code enclosures and prior test scenarios
Code = {tag}
The SQL engine will recognise it as a string.
Please see Wiki - how to post code on this forum.
That was the first thing a I tried. I see I didn’t include that in the original post.
Code = {tag}
and got the error
Error during group execution. com.microsoft.sqlserver.jdbc.SQLServerException: Incorrect syntax near 'C'. Incorrect syntax near 'C'.
So it appears the tag is not being sent as a string.
If I set the value ot {tag} to the literal string ‘0001C’ then
Code={tag}
works
Show us your whole query. Please see Wiki - how to post code on this forum.
There is no query, per se. This is in the Where portion of the Table action for a block item transaction. I don’t see a way to view the actual query.
Sorry, I've never used the Block Group so I don't think I can help further. There is a section in the docs and there's an IU video. Block Group | Ignition User Manual.
Understandable. The videos and manual don’t get this deep into the specifics. Typically one of the “cheat codes” above works.
This looks like a bug in the parsing logic.
As a workaround, can you try adding that tag as a run always expression and set it as a string?
Then use that in the WHERE clause?
Great idea. That didn’t work but I can add an expresssion item tag and use.
concat("'",{[default]tag},"'")
Then the where clause is
CODE={[~]Expression Item}
that’s a valid workaround. Thanks
If I was you, I would still open a ticket with support so they can investigate and fix if it turns out to be a real bug.
Does it work if you use an expression tag without the concat with the apostrophes in the where clause?
CODE='{[~]Expression Item}'
What version of Ignition are you running? I’ve definitely done this before in standard transaction groups.
I’m curious if the issue is specific to one of the following:
  1. Referencing a tag from outside the group
  2. Block transaction groups specifically
  3. The version of Ignition
Funny you should mention that. I did submit a ticket.
Interestingly, that does work.
Using version 8.3.0
