Add data to historian
Hello,
I created some new tags and saved their data using the historian.
and when I try to see the data it works just fine.
I have data of this tags before I created them in the ignition - in access
and I want to add this data to the historian,
How can I do that?
I found the tag id’s in the “sqlth_te”
and inserted the data to the right partition of the month(e.g : sqlt_data_1_2020_01) with the right timestamp,
but I cant see the data using the historian.
Could you help please?
thanks
Consider re-doing your data import using the (only) supported method: system.tag.storeTagHistory().
