Add days but exclude weekends
Hello,
I tried to make a perspective script to add days but exclude weekdays. Everything fine on Script Console but when I test it on Perspective, I have the next error.
Error running property change script on DateTimeInput.props.value: Traceback (most recent call last): File “function:valueChanged”, line 39, in valueChanged File “function:valueChanged”, line 32, in date_by_adding_business_days AttributeError: type object ‘datetime’ has no attribute ‘timedelta’
My Script:
from datetime import timedelta
from datetime import datetime
z = '20220303' #date
def date_by_adding_business_days(from_date, add_days):
	business_days_to_add = add_days
	current_date = from_date
	while business_days_to_add > 0:
		current_date += datetime.timedelta(days=1)
		weekday = current_date.weekday()
		if weekday >= 5: # sunday = 6
			continue
		business_days_to_add -= 1
	return current_date
self.view.getChild("root").custom.test5 = date_by_adding_business_days(z, 20)
Script console
Use the system.date.* functions or java’s timezone objects if you need localization.
I would write it like this:
holidays = [system.date.getDate(2022,2,7)]  #just adding a day for testing purposes
def isWeekend(date):
	if system.date.getDayOfWeek(date) in [1,7]:
		return True
	return False
def isHoliday(date):
	if holidays and date in holidays:
		return True
	return False
def addBusinessDays(date,days):
	returnDate = system.date.setTime(date,0,0,0)
	while days > 0:
		returnDate = system.date.addDays(returnDate,1)
		if not isWeekend(returnDate) and not isHoliday(returnDate):
			days -= 1
	return returnDate
print addBusinessDays(system.date.now(),1)
Output:
Tue Mar 08 00:00:00 EST 2022
Awesome. It works absolutely perfectly, thank you very much for your help.
