Add elements to a JSON file?
I am working on a transform, but I don't know the pythonic approach to solve this:
if I have this array:
list = [{'NestID': '1', 'Ch2': '68'}, {'NestID': '2', 'Ch2': '133'}, {'NestID': '3', 'Ch2': '65'}, {'NestID': '4', 'Ch1': '2'}]
How do I modify it so I can change the 1st and 3rd element of this list to be like this:
{'NestID': '2', 'Ch2': '133', 'Ch3': '20'}
{'NestID': '4', 'Ch1': '2','Ch2': '7','Ch4': '9'}]
So that my entire list changes to:
[{'NestID': '1', 'Ch2': '68'}, {'NestID': '2', 'Ch2': '133', 'Ch3': '20'}, {'NestID': '3', 'Ch2': '65'}, {'NestID': '4', 'Ch1': '2','Ch2': '7','Ch4': '9'}]
This is a somewhat underspecified problem.
Are the NestID values always guaranteed to be in order? Are they really strings? Is the actual operation you need to do always going to be adding additional keys, or is it a replacement of existing keys? Or do you want to merge new keys into the existing dictionary? Is your JSON structure guaranteed to be a list of flat objects? Can you modify the existing list (don't name variables list, by the way), or do you need to return a deep-copied new list?
Depending on the answers to those questions, the approach may change significantly.
One simple answer would be something like this:
inputList = [
def update(json, nestId, newValue):
    index = -1
    for i, obj in enumerate(json):
        if obj['NestID'] == nestId:
            index = i
    if index >= 0:
        json[index] = newValue
update(inputList, '2', {'NestID': '2', 'Ch2': '133', 'Ch3': '20'})
update(inputList, '4', {'NestID': '4', 'Ch1': '2','Ch2': '7','Ch4': '9'})
# output
#     {'NestID': '1', 'Ch2': '68'},
#     {'NestID': '2', 'Ch2': '133', 'Ch3': '20'},
#     {'NestID': '3', 'Ch2': '65'},
#     {'NestID': '4', 'Ch1': '2','Ch2': '7','Ch4': '9'}
Many Thanks:
Are the NestID values always guaranteed to be in order? Yes
Are they really strings? Only strings (and maybe integers in the future)
Is the actual operation you need to do always going to be adding additional keys? Yes
or is it a replacement of existing keys? No
Or do you want to merge new keys into the existing dictionary? Yes
If you're always merging in new keys, then one option for improvement:
def update(json, nestId, **newKeys):
    index = -1
            index = i
    if index >= 0:
        currentValue = json[index]
        currentValue.update(newKeys)
update(inputList, '2', Ch3='20')
update(inputList, '4', Ch2='7', Ch4='9')
Thank you so much for your help! I really appreciate it. Many, many thanks
I am not sure why is not doing it
#// This example create a single column dataset.
headers = ['col1', 'col2', 'col3']
list1= [
[1, 30, 68],
[2, 23, 133],
[3, 25, 65],
[4, 23, 145],
[5, 22, 2],
[5, 31, 8],
[5, 32, 30],
[6, 11, 3],
[6, 20, 241],
[7, 22, 2],
[7, 19, 202],
[8, 19, 2],
[8, 24, 241],
[8, 13, 30],
[9, 18, 19],
[10, 13, 4]]
mylist = system.dataset.toPyDataSet(system.dataset.toDataSet(headers, list1))
listOfRowValues=
for row in mylist:
listOfRowValues.append(row[0])
print (row[0],row[1],row[2])
#// create a dictionary
failCodeDesc = {10: "Ch1",
11: "Ch2",
12: "Ch3",
13: "Ch4",
18: "Ch1",
19: "Ch2",
20: "Ch3",
21: "Ch4",
22: "Ch1",
23: "Ch2",
24: "Ch3",
25: "Ch4",
30: "Ch1",
31: "Ch2",
32: "Ch3",
33: "Ch4"}
newData =
index = -1
index = i
if index >= 0:
nest1 = mylist.getColumnAsList(0) #channel list
failCode1 = mylist.getColumnAsList(1) #failcode list
counts1 = mylist.getColumnAsList(2) #amount of failcodes list
#// get list of values using map
channels1 = list(map(failCodeDesc.get, failCode1))
for data in mylist:
for i, (w,x,y,z) in enumerate(zip(nest1, failCode1,counts1,channels1)):
#checking for duplicates in the first column (duplicate NestIDs)
if ((i != 0) and (nest1[i]== nest1[i-1])): #check if the firs value of first column (nestID) is the same as the previous one
update(newData, nest1[i], {channels1[i]:str(counts1[i])})
else: #else, if there's unique numbers at the first column (unique NestIDs)
newData.append({'NestID': str(nest1[i]), channels1[i]:str(counts1[i])})
break
for i in range(0, len(newData)):
print(newData[i])
I get this:
{'NestID': '1', 'Ch1': '68'}
{'NestID': '3', 'Ch4': '65'}
{'NestID': '4', 'Ch2': '145'}
{'NestID': '5', 'Ch1': '2'}
{'NestID': '6', 'Ch2': '3'}
{'NestID': '7', 'Ch1': '2'}
{'NestID': '8', 'Ch2': '2'}
{'NestID': '9', 'Ch1': '19'}
{'NestID': '10', 'Ch4': '4'}
Script Console Code.txt (2.1 KB)
But, I am expecting this:
{'NestID': '5', 'Ch1': '2','Ch2': '18','Ch3': '30'}
{'NestID': '6', 'Ch2': '3','Ch3': '241'}
{'NestID': '7', 'Ch1': '2','Ch2': '202'}
{'NestID': '8', 'Ch2': '2','Ch3': '241','Ch4': '30'}
The update function was never getting called because nest1[i] was an integer, but the value you were checking against was a string. Types are very important.
# This example create a single column dataset.
list1= [
[1, 30, 68],
[2, 23, 133],
[3, 25, 65],
[4, 23, 145],
[5, 22, 2],
[5, 31, 8],
[5, 32, 30],
[6, 11, 3],
[6, 20, 241],
[7, 22, 2],
[7, 19, 202],
[8, 19, 2],
[8, 24, 241],
[8, 13, 30],
[9, 18, 19],
[10, 13, 4]]
listOfRowValues=[]
for row in mylist:
# create a dictionary
				11: "Ch2",
				12: "Ch3",
				13: "Ch4",
				18: "Ch1",
				19: "Ch2",
				20: "Ch3",
				21: "Ch4",
				22: "Ch1",
				23: "Ch2",
				24: "Ch3",
				25: "Ch4",
				30: "Ch1",
				31: "Ch2",
				32: "Ch3",
				33: "Ch4"}
newData = []
    index = -1
            index = i
    if index >= 0:
# get list of values using map
for data in mylist:
			updates = {channels1[i]:str(counts1[i])}
			update(newData, str(nest1[i]), **updates)
	break
    print(newData[i])
(1, 30, 68)
(2, 23, 133)
(3, 25, 65)
(4, 23, 145)
(5, 22, 2)
(5, 31, 8)
(5, 32, 30)
(6, 11, 3)
(6, 20, 241)
(7, 22, 2)
(7, 19, 202)
(8, 19, 2)
(8, 24, 241)
(8, 13, 30)
(9, 18, 19)
(10, 13, 4)
{'NestID': '5', 'Ch2': '8', 'Ch1': '2', 'Ch3': '30'}
{'NestID': '6', 'Ch2': '3', 'Ch3': '241'}
{'NestID': '7', 'Ch2': '202', 'Ch1': '2'}
{'NestID': '8', 'Ch2': '2', 'Ch4': '30', 'Ch3': '241'}
There is likely a much more ergonomic, efficient way to gather your data together, but I'll let @JordanCClark or someone else tag in :slight_smile:
Thank you so much!!
Ack! I've been sniped!
# Sample Dataset
list1= [
		[1, 30, 68],
		[2, 23, 133],
		[3, 25, 65],
		[4, 23, 145],
		[5, 22, 2],
		[5, 31, 8],
		[5, 32, 30],
		[6, 11, 3],
		[6, 20, 241],
		[7, 22, 2],
		[7, 19, 202],
		[8, 19, 2],
		[8, 24, 241],
		[8, 13, 30],
		[9, 18, 19],
		[10, 13, 4]
				11: "Ch2",
				12: "Ch3",
				13: "Ch4",
				18: "Ch1",
				19: "Ch2",
				20: "Ch3",
				21: "Ch4",
				22: "Ch1",
				23: "Ch2",
				24: "Ch3",
				25: "Ch4",
				30: "Ch1",
				31: "Ch2",
				32: "Ch3",
				33: "Ch4"}
dictOut = {}
for row in mylist:
	nestID, channelID, value = list(row)
	# Check if nestID already exists
	if nestID not in dictOut.keys():
		dictOut[nestID] = {}
	# add channel info
	dictOut[nestID][failCodeDesc[channelID]] = str(value)
# Create json Output
jsonOut = []
for nestID in sorted(dictOut.keys()):
	newRow = {'NestID':str(nestID)}
	newRow.update(dictOut[nestID])
	jsonOut.append(newRow)
	print newRow
print jsonOut
Thank you very much!!
Adding some nanoTime info in there, taking out the print statements.
Paul's script
0.8152 ms
0.5495 ms
0.6138 ms
0.5476 ms
0.5409 ms
0.5716 ms
0.5813 ms
0.6102 ms
0.587 ms
0.5272 ms
My first nerd-sniped script:
0.4069 ms
0.2438 ms
0.2432 ms
0.2385 ms
0.47 ms
0.4183 ms
0.2496 ms
0.2366 ms
0.2565 ms
0.4105 ms
my second sniped script (Thanks, Paul, for making my brain interrupt my first cup of coffee)
This one puts the NestID key in the nested dictionary up front, avoiding the dict.update() in the second pass.
dictOut = {}
for row in mylist:
		dictOut[nestID] = {'NestID':str(nestID)}
	# add channel info
jsonOut = []
	jsonOut.append(dictOut[nestID])
Timing:
0.3332 ms
0.2807 ms
0.2031 ms
0.204 ms
0.2443 ms
0.3418 ms
0.2246 ms
0.2184 ms
0.218 ms
0.2696 ms
In the grand scheme of things, a few tenths of a millisecond may not matter. It just depends how many rows in your dataset you need to process.
