Add item to a node's right click popup menu
In my module, I am trying to add an item to a node’s right click popup menu. Specifically, in the Project Browser -> Project -> Scripts -> Script Library tree path, I want to add a custom “export as text file” item to the right click popup menu for each of the scripts within. Is there a way to do this? Thank you!
Got word that this just might not be possible… but I might continue to try to hack at it later.
Hello fourmajor, were you able to ever get this to work because i am trying to look into doing something similar at the moment. All the popup classes I see on ignition seem to be for creating a new popup menu but nothing seems to allow me to edit a pre-existing default ignition pop up menu. Thanks.
