I've some trouble adding items to a menu tree with scrip.
I'd like to add items with a script when a new MQTT edge nodes appear in my MQTT engine tag provider.
Is there first a simple way to add items to a menu tree with a event script ??
Hello. I would leverage a timed event script on the gateway to handle this. It would give more predictable cadence than a tag change on a folder which can execute on quality, timestamp,value changes, etc.
See this code below, I think it will get you started.
item = {
"target": "",
"items": [],
"navIcon": {
"path": ""
"label": {
"text": "",
"icon": {
"path": "material/lens",
"style": {
"classes": "B_Labels/Navigation/AlarmOff"
"visible": True,
"enabled": True,
"showHeader": False,
"resetOnClick": False,
"backActionText": "",
"style": {
"classes": "B_Labels/Navigation/BackgroundUnselected"
newitem = item
newitem['enabled'] = your_data
newitem['label']['text'] = your_data
self.getChild("MenuTree").props.items.append(newitem)
Regards,
Frank
Is there a reason you're not using the Tag Browse Tree component?
