I would like to add some Javascript code in a perspective module based on the pespective-component-minimal example from @PerryAJ.
<script type="text/javascript" src="external-lib.js"></script>
is there a way to achieve this, from onecomponent.js file:
* This javascript file was hand-written in pure javascript to demonstrate the minimal implementation required to
* register a single new component for use in perspective.
const { Component, ComponentRegistry } = window.PerspectiveClient;
* Each component requires the definition of a 'Meta Object' which contains information about the component. This
* meta object is what is registered to the client-side (web browser environment) component registry. A similar
* registration is required on the Gateway (server) side.
* The structure of the Meta Object is defined by the Typescript interface that is published as part of the
* `@inductiveautomation/perspective-client` npm package. Implemented below is the minimal required elements for
* a component.
class ImageMeta {
// the string 'type id' for the component. Best practice is to use reverse domain prefixes to avoid collisions.
getComponentType() {
return "com.gh.ia.simple.img";
// the class or React Type that this component provides
getViewComponent() {
return Image;
// the size of the initial component.
getDefaultSize() {
return ({
width: 360,
height: 360
// Invoked when an update to the PropertyTree has occurred,
// effectively mapping the state of the tree to component props.
getPropsReducer(tree) {
return {
url: tree.readString("url", "")
* The Component implementation.
* Components in Perspective are React components that extend from perspective-client's `Component` class.
class Image extends Component {
render() {
// The props we're interested in.
const { props: { url }, emit } = this.props;
// Read the 'url' property provided by the perspective gateway via the component 'props'.
// Note that the topmost piece of dom requires the application of an element reference, events, style and
// className as shown below otherwise the layout won't work, or any events configured will fail. See render
// of MessengerComponent in Messenger.tsx for more details.
return (React.createElement("img", Object.assign({}, emit(), { src: url, alt: `image-src-${url}` })));
ComponentRegistry.register(new ImageMeta())
perhaps with useEffect ?
