Addin the Ignition Perspective Icons into a vision client
Hey all,
I have a project where we will want to use the features of Vision for some HMI clients, but have the client similiar in appearance to the Perspective pages we had been developing.
This is fine so far, as it's mostly just recolouring stuff, but is there a good way of getting the perspective icons into a vision client, in a way that can be recoloured, or should I just get try to import them as SVG images and edit those in the designer?
What I've done is gone to the google materials icons: Material Symbols and Icons - Google Fonts and finding the one that matches what I want that matches the perspective side, downloaded and then drug into a template for it to create the lines etc... from the SVG. Then saved it as the name of the material icon in the template library so that it can be reused later.
You can also get the PNG version of many of these icons from the GithHub repo, and place those in your gateway via image management. (I do this to supplement the built-in icons, too.)
