Adding a transform to Table Data being written from a property change script
Hello everyone!
I am using a property change script to write data to a table. I then need to add a transform to modify the colors of the rows of the table depending on the value inside of them. When Trigger becomes True, it runs a query and moves that data into the table. I did it this way so that I could parameterize the query that it runs.
def valueChanged(self, previousValue, currentValue, origin, missedEvents):
	if previousValue and (previousValue.value != currentValue.value):
		TableData = system.db.runNamedQuery(self.view.params.NamedQueryName)
		self.getSibling("Table").props.data = TableData
Here is the code that works as a transform to change the table row colors:
    output_json = []
    style_orange = {"backgroundColor": "#d61a3c"}
    style_green = {"backgroundColor": "#00b050"}
    for row in range(value.getRowCount()):
            row_object = {}
            row_value = {}
            row_style = {}
            for col in range(value.getColumnCount()):
                row_value[value.getColumnName(col)] = value.getValueAt(row, col)
                row_object['value'] = row_value
                if value.getColumnName(col) == 'CycleDelta':
                    if value.getValueAt(row, col) < 0:
                        row_style = style_orange
                    elif value.getValueAt(row, col) >= 0:
                        row_style = style_green
                row_object['style'] = row_style
            output_json.append(row_object)
    return output_json
Is there a way for me to add the transform?
Run the second script as part of your first script. Do it all in the one script.
Why do you need a transform? Is the table also updating based on a binding?
Just put the function in a library script, and call it at the end of your script prior to setting the table's data prop.
I tried that, the issue is the script uses value.GetColumnCount which throws an error.
Provide value as a function argument to your library function.
So at the end of my script I can call the RowColor function and pass value in. Except value isn't something that exists yet in my property change script. How would I define value such that the library script will be able to call value.GetRowCount and value.GetValue
It's TableData.
So, something like this:
self.getSibling("Table").props.data = someScript.myTransform(TableData)
Your transform becomes:
return someScript.myTransform(value)
Create your library script like this:
def setTableRowColors(params):
    value = system.db.runNamedQuery(params)
    #insert your "transform script here"
Then your property change script would become:
        self.getSibling("Table").props.data = yourLibrayScriptName.setTableRowColors(self.view.params.NamedQueryName)
Thank you both! Have a good weekend and Happy Memorial Day!
