Hi All,
We have a requirement that when a tag value is changed from perspective client, For example a setpoint change of a tag. We need to see the log as XXXtag value changed from XX to XXX with some reason added to it. As ignition default audit log data does not show this kind of log, we thought to add extra columns to the “audit_events” table (This was automatically created when we enable audit log option in project property) and manually push event log by a button press or from input field components etc.,
Will this breaks anything? and ignition audit trail will not function normally?
can anyone please suggest on this?
Rajesh
