Adding images to dropdownOptionStyle
Hi, I want to add small images (in this example from the Builtin library under “Image Management”) to the options of a dropdown, by scripting.
My Code currently looks like this (image is only an example):
dropdownOptionStyle = {
    "background-image"		: "url('/icon/48/pencil.png')",
    "background-size"		: "48px 48px",
	"background-position"	: "left center",
 	"background-repeat"		: "no-repeat",
 	"line-height"			: "50px",
 	"padding-left"			: "50px",
	"fontStyle"				: "italic",
	"color"					: "green",
I can see the fonts just fine, but I can´t see the images.
If I try to add them through content: url(...) I´m seeing nothing.
It would be nice if it was possible to assign an image to each option.
What could I do ? Thanks in advance.
You need to add "/system/images" as a prefix to your image url.
Not sure you'll be able to insert the image directly before the text without using the advanced stylesheet.css ...
Also, you unfortunately won't be able to specify a different image for each option without some clunky implementation (or develop your own module!)
Might want to take a look at this one, if you need different icons/images per option.
Thank you very much. I can see the image now.
But I did not understand the script completely. I have to use a binding with a markdown-component instead script ? Where exactly do I have to put the binding? If I try:
optionList = []
for option in locals:
	optionList.append({
	"value": option,
	"label": option,
	"style": {"color": "red"}
self.getChild("root").getChild("FlexContainer_top").getChild("DD_languageTag").props.options = optionList
It dosen´t accept the style property. which is unfortunate.
you replied to the wrong person i think :stuck_out_tongue:
yes on the bottom of the topic there is someone who linked his post where he goes into more depth using my markdown if you are unfamiliar with it
Anyways if its for some static flags, you can just add the styles in stylesheet.css for every flag.
give your dropdownOptionsStyle a class example "cssFlags"
.psc-cssFlags[data-label="de"] {
    color: #FF0000
for none static things you'll need the markdown to add these styles
Thank you so much, I found something after going though that page : Change color for each option based on some category for Perspective Dropdown Component - #6 by Elizabeth_Engler
In the end my Code looks kind of like this:
# for extra styling of the dropdown content
		"background-color"		: "transparent",
   	 	"padding-left"			: "10px",
    	"color"					: "green",
    # define the variable here to "save" complete HTML string
	markDownStyle= ""
	#Get locals
	locals = package.getAvailableLocales()
	# import all needed images from the Image Management (pictures have to be uploaded FIRST !)
	imgUrlUK = '/system/images/contryIcons/united-kingdom.png'
	imgUrlDE = '/system/images/contryIcons/german.png'
	# create an optionlist with all locals
	optionList = []
	# for each option 1.build the option and 2. add style
		# cast java.Locale to string
		option = str(option)
		optionList.append({
		"value": option,
		"label": option,
		# choose imageUrl depending on option
		imgUrl = ""
		if option == "de":
			imgUrl = imgUrlDE
		elif option == "en":
			imgUrl = imgUrlUK
		markDownStyle = markDownStyle + """.iaDropdownCommon_options [data-label=""" + option + """
						]:before { content: url(""" + imgUrl + """);}"""
	# build the styling with the accumulated markDownStyle
	markDowncode =  """<style>
				""" + markDownStyle + """
				</style>"""
	# format the string nicer, to make sure the HTML is valid
	markDowncode = markDowncode.replace("\n", " ").replace("\t", "")
	# set the properties
	self.getChild("root").getChild("FlexContainer_top").getChild("DD_languageTag").props.dropdownOptionStyle = dropdownOptionStyle
	self.getChild("root").getChild("FlexContainer_top").getChild("Markdown").props.source = markDowncode
Thank you very much for your help. :grinning:
Edit: forgot to add image:
