If you create a datatype instance, and the manually add a new tag in the instance you cannot edit it.
Right_click Edit Tag takes you to the data type instance not the new tag.
This has been fixed in newer versions of Ignition. Now you cannot add new tags to instances of a UDT, you must create another UDT that uses the first.
