Adding Settings
Pretty new to Ignition Development
I want to add a settings page to my module, I have created an registered a PersistentRecord but it doesn’t show up anywhere in the settings page.
What am I missing?
Here’s my current PersistentClass
package com.jnjdodev.ignition.modules.websocket;
import com.inductiveautomation.ignition.gateway.localdb.persistence.Category;
import com.inductiveautomation.ignition.gateway.localdb.persistence.IdentityField;
import com.inductiveautomation.ignition.gateway.localdb.persistence.IntField;
import com.inductiveautomation.ignition.gateway.localdb.persistence.PersistentRecord;
import com.inductiveautomation.ignition.gateway.localdb.persistence.RecordMeta;
import simpleorm.dataset.SFieldFlags;
public class WebSocketsRecord extends PersistentRecord {
	private static final long serialVersionUID = 1L;
	public static final RecordMeta<WebSocketsRecord> META = new RecordMeta<>(
			WebSocketsRecord.class, "WebSocketsRecord").setNounKey("WebSocketsRecord.Noun")
            .setNounPluralKey("WebSocketsRecord.Noun.Plural");
	public static final IdentityField Id = new IdentityField(META);
	 public static final IntField WebSocketPort = new IntField(META, "WebSocketPort",
	            SFieldFlags.SMANDATORY).setDefault(23333);
	@Override
	public RecordMeta<?> getMeta() {
		// TODO Auto-generated method stub
		return META;
	public void setPort(int port)
		this.setInt(WebSocketPort, port);
	public int getPort()
		return this.getInt(WebSocketPort);
	static final Category SeeqServerConfiguration =
            new Category("WebSocketsRecord.Category.Configuration", 1000)
                    .include(WebSocketPort);
and my GatewayHook Setup
public void setup(GatewayContext context) {
		this.context = context;
		try {
			this.context.getSchemaUpdater().updatePersistentRecords(WebSocketsRecord.META);
		} catch (SQLException e) {
			// TODO Auto-generated catch block
			e.printStackTrace();
You have to construct one or more configuration pages to be shown, and override the gateway hook’s getConfigPages() method. Welcome to Wicket!
Fortunately this is pretty easy because you just extend RecordEditForm:
public class SettingsPage extends RecordEditForm {
    public SettingsPage(final IConfigPage configPage) {
        super(configPage, null, new LenientResourceModel("xopc.config.settings.paneltitle"),
            ((GatewayContext) Application.get()).getPersistenceInterface().find(
                XOPCSettingsRecord.META, 0L));
    @Override
    public Pair<String, String> getMenuLocation() {
        return Pair.of(XOPCGatewayHook.OPCUA_CATEGORY.getName(), "settings");
This is the UA module’s server settings page. There’s only ever one instance of this settings record, so it doesn’t even need to have a record passed in to the constructor.
There doesn't appear to be a getConfigPages() in my current Hook
I'm on version 8.0.1
There appears to be a getConfigPanels()
Is this what I want?
Ah, it changed a bit in 8.0.
Check out this example: https://github.com/inductiveautomation/ignition-sdk-examples/tree/master/gateway-webpage
My mistake. My own v8 module I looked at overrides getConfigPanels(). And it was true for v7.9 as well.
Thanks @Kevin.Herron
Trying to follow that example I have the following now
In Hook:
@Override
    public List<ConfigCategory> getConfigCategories() {
        return Collections.singletonList(CONFIG_CATEGORY);
	public static final ConfigCategory CONFIG_CATEGORY =
	        new ConfigCategory("WebSocket", "WebSocketHeader", 700);
	 public static final IConfigTab HCE_CONFIG_ENTRY = DefaultConfigTab.builder()
	            .category(CONFIG_CATEGORY)
	            .name("WebScocketSettings")
	            .i18n("WebSocketSettings")
	            .page(SettingsPage.class)
	            .build();
	 @Override
	    public List<? extends IConfigTab> getConfigPanels() {
		            HCE_CONFIG_ENTRY
Along with the SettingsPage similar to what you suggested
            		WebSocketsRecord.META, 1L));
    @Override
        return Pair.of("WebSocket", "WebScocketSettings");
And I am getting this which is progress!
But clicking on it just yields : Internal error
With the log having the following
Exception
org.apache.wicket.WicketRuntimeException: Can't instantiate page using constructor 'public com.inductiveautomation.ignition.gateway.web.pages.Config(org.apache.wicket.request.mapper.parameter.PageParameters)' and argument 'path=[WebSocket.WebScocketSettings]'. Might be it doesn't exist, may be it is not visible (public).
at org.apache.wicket.session.DefaultPageFactory.newPage(DefaultPageFactory.java:193)
at org.apache.wicket.session.DefaultPageFactory.newPage(DefaultPageFactory.java:98)
at org.apache.wicket.DefaultMapperContext.newPageInstance(DefaultMapperContext.java:137)
at org.apache.wicket.core.request.handler.PageProvider.resolvePageInstance(PageProvider.java:278)
at org.apache.wicket.core.request.handler.PageProvider.getPageInstance(PageProvider.java:166)
at org.apache.wicket.request.handler.render.PageRenderer.getPage(PageRenderer.java:78)
at org.apache.wicket.request.handler.render.WebPageRenderer.renderPage(WebPageRenderer.java:94)
at org.apache.wicket.request.handler.render.WebPageRenderer.respond(WebPageRenderer.java:244)
at org.apache.wicket.core.request.handler.RenderPageRequestHandler.respond(RenderPageRequestHandler.java:165)
at org.apache.wicket.request.cycle.RequestCycle$HandlerExecutor.respond(RequestCycle.java:814)
at org.apache.wicket.request.RequestHandlerStack.execute(RequestHandlerStack.java:64)
at org.apache.wicket.request.cycle.RequestCycle.execute(RequestCycle.java:253)
at org.apache.wicket.request.cycle.RequestCycle.processRequest(RequestCycle.java:210)
at org.apache.wicket.request.cycle.RequestCycle.processRequestAndDetach(RequestCycle.java:281)
at org.apache.wicket.protocol.http.WicketFilter.processRequest(WicketFilter.java:188)
at org.apache.wicket.protocol.http.WicketFilter.doFilter(WicketFilter.java:245)
at com.inductiveautomation.ignition.gateway.bootstrap.GatewayFilter.doFilter(GatewayFilter.java:74)
at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1629)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:533)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:132)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:190)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1595)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:188)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1253)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:168)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:473)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1564)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:166)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1155)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
at org.eclipse.jetty.server.handler.HandlerList.handle(HandlerList.java:61)
at org.eclipse.jetty.rewrite.handler.RewriteHandler.handle(RewriteHandler.java:335)
at org.eclipse.jetty.server.handler.HandlerCollection.handle(HandlerCollection.java:126)
at org.eclipse.jetty.server.Server.handle(Server.java:530)
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:347)
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:256)
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:279)
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:102)
at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:124)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:247)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.produce(EatWhatYouKill.java:140)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:131)
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:382)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:708)
at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:626)
Caused by: java.lang.reflect.InvocationTargetException: null
at jdk.internal.reflect.GeneratedConstructorAccessor62.newInstance(Unknown Source)
at java.base/jdk.internal.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
at java.base/java.lang.reflect.Constructor.newInstance(Unknown Source)
at org.apache.wicket.session.DefaultPageFactory.newPage(DefaultPageFactory.java:170)
... 50 common frames omitted
Caused by: java.lang.RuntimeException: Unable to create config panel WebSocket.WebScocketSettings
at com.inductiveautomation.ignition.gateway.web.models.DefaultConfigTab.getPanel(DefaultConfigTab.java:99)
at com.inductiveautomation.ignition.gateway.web.pages.Config.(Config.java:109)
... 54 common frames omitted
at java.base/jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at java.base/jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
at com.inductiveautomation.ignition.gateway.web.models.DefaultConfigTab.getPanel(DefaultConfigTab.java:91)
... 55 common frames omitted
Caused by: java.lang.ClassCastException: class com.inductiveautomation.ignition.gateway.web.IgnitionWebAppImpl cannot be cast to class com.inductiveautomation.ignition.gateway.model.GatewayContext (com.inductiveautomation.ignition.gateway.web.IgnitionWebAppImpl and com.inductiveautomation.ignition.gateway.model.GatewayContext are in unnamed module of loader 'app')
at com.jnjdodev.ignition.modules.websocket.SettingsPage.(SettingsPage.java:20)
... 60 common frames omitted
Any suggestions as to what I’m doing wrong? I’m trying to follow that example but I can’t seem to get past this point.
Thanks!
Correction, I see the error is that it wants IgnitionWebApp instead of GateWayContext which I’ve corrected.
New Error:
Exception
Caused by: java.lang.NullPointerException: null
at com.inductiveautomation.ignition.gateway.web.models.DirectRecordListModel.(DirectRecordListModel.java:46)
at com.inductiveautomation.ignition.gateway.web.models.CompoundRecordModel.(CompoundRecordModel.java:48)
at com.inductiveautomation.ignition.gateway.web.models.CompoundRecordModel.(CompoundRecordModel.java:41)
at com.inductiveautomation.ignition.gateway.web.components.RecordEditForm.(RecordEditForm.java:65)
at com.jnjdodev.ignition.modules.websocket.SettingsPage.(SettingsPage.java:21)
Still investigating
The root cause is this:
Copy the page from the example rather than the one I posted, which came from 7.9.
So now it’s having a hard time with my “Path” “WebSocket.WebScocketSettings”
I see that’s what I’m passing to CONFIG_CATEGORY
	        new ConfigCategory("WebSocket", "WebScocketSettings", 700);
And then I’m using that in my CONFIG_ENTRY
	            .i18n("WebScocketSettings")
	            .build();
It seems to be taking issue with that (some how) but I’m not sure I follow what it wants. Any pointers?
Sorry in advance, If i’m missing something obvious
Here is my persistence class if it matters
	@Override
		return META;
Does your SettingsPage still have the public IConfigPage constructor?
Yes it does, should it not?
It should, but the error’s indicating that it doesn’t:
Is it just a typo? You’ve got "WebScocketSettings" in a few code snippets.
Yeah it’s just a typo but a consistent Typo lol… I think (Double checking)
ok So I’ve double checked everything and still can’t figure it out. I’m gonna post my files one more time hoping someone can see what I’m missing.
SettingsPage.java
I’m using LenientResourceModel(“xopc.config.settings.paneltitle”) from above not sure if that’s right or what exactly does it mean? Examples seems to have their own?
	public static final Pair<String, String> MENU_LOCATION =
	        Pair.of(WebSocketGatewayHook.CONFIG_CATEGORY.getName(), "Settings");
            ((IgnitionWebApp) Application.get()).getContext().getPersistenceInterface().find(
            		WebSocketsRecord.META, 0L));
    @Override
    	return MENU_LOCATION;
My persistance Record
	@Override
		return META;
Hook class
		try {
		    maybeCreateWebSocketSettings(context);
public void maybeCreateWebSocketSettings(GatewayContext context) {
        logger.trace("Attempting to create GitConnector Settings Record");
        try {
            WebSocketsRecord settingsRecord = context.getLocalPersistenceInterface().createNew(WebSocketsRecord.META);
            settingsRecord.setPort(23333);
             * This doesn't override existing settings, only replaces it with these if we didn't
             * exist already.
            context.getSchemaUpdater().ensureRecordExists(settingsRecord);
        } catch (Exception e) {
@Override
	        new ConfigCategory("WebSocket", "WebSocket", 700);
	            .name("Settings")
	            .i18n("WebSocket")
	            .build();
	 @Override
		            HCE_CONFIG_ENTRY
Getting this error when I click on the menu item
Exception
org.apache.wicket.WicketRuntimeException: Can't instantiate page using constructor 'public com.inductiveautomation.ignition.gateway.web.pages.Config(org.apache.wicket.request.mapper.parameter.PageParameters)' and argument 'path=[WebSocket.Settings]'. Might be it doesn't exist, may be it is not visible (public).
Caused by: java.lang.RuntimeException: Unable to create config panel WebSocket.Settings
at com.jnjdodev.ignition.modules.websocket.SettingsPage.(SettingsPage.java:25)
Lastly the menu Item seems to be kinda weird with a bunch of question marks around it?
Any ideas are really appreciated!
I"ve managed to write an entire working module but can’t figure out the Settings page LoL!
Thanks again~!
The question marks are because you haven’t loaded a bundle of translation properties for the resource keys you have provided. (Similar to the properties specific to the settings record, which get autoloaded.) Look at the BundleUtil class.
Thanks @pturmel I’ll give that a shot
Thanks @pturmel that fixed all my issues
