I have added a Siemens device and have OPC-UA in Ignition. I added some tags from the Tag Browser "OPC Tags using Siemens Driver." Now, I am using another OPC UA client and want to read the Siemens tags that I added, but I can not see them.
Is it possible "to add Siemens tag to the Ignition OPC UA server and access them from other OPC client"?
and how to do that.
Regards,
You could expose the Ignition tags you created using the Exposed Tags feature, but it's not possible to make tags appear on the driver for 3rd party clients (nor for the Ignition client itself).
To access those tags the 3rd party client must have the ability to manually specify a NodeId just like you do when manually specifying the OPC Item Path for an Ignition OPC tag pointing at a Siemens device.
